Injector #4 mechanical malfunction
Discussion in 'Volvo Forum' started by Kakmos, Aug 24, 2018.
  1. Kakmos
    Kakmos Bobtail Member
    20
    5
    Aug 24, 2018
    Hey guys I have an 09 volvo vnl 670. It's showing "injector #4 mechanical fault" . I have changed all injectors and caps, wiring harness and ecm but the code won't go away and the truck idles rough. Somebody pls help....
  3. mhyn
    mhyn Road Train Member
    4,255
    4,513
    Dec 29, 2008
    Northridge, CA
    what engine ?
  4. Kakmos
    20
    5
    Aug 24, 2018
  5. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    Head problem possibly turbo for sure burned valve or bad cam one or the other wither or very expensive fix
    Justrucking2 and QUALITYTRUCK Thank this.
  6. QUALITYTRUCK
    1,804
    1,765
    Jun 14, 2009
    romulus,mi
    I will bet on bad camshaft lobe.
  7. Kakmos
    20
    5
    Aug 24, 2018
    My mechanic removed the valve cover did a visual check. He says everything seems fine. Can you tell a bad camshaft lobe by a visual inspection or you have to take it apart?
  8. QUALITYTRUCK
    1,804
    1,765
    Jun 14, 2009
    romulus,mi
    Sometimes you are able to see it clearly in plain sight. If he could not, then he will have to remove rocker shaft (VERY HEAVY), inspect rocker arms and rotate engine while inspecting camshaft.
  9. Goodysnap
    Goodysnap Road Train Member
    3,716
    9,022
    Jul 12, 2017
    Every engine can be checked for cam lift without disassembly. If you have an issue where cylinder is not producing power and you suspect a valvetrain issue, valve lift can be measured with a dial indicator to match a known good cylinder or engine manufacturer specs.
    This is a way to check cam integrity without teardown. This in no way inspects the parts for reuse or surface integrity and obviously teardown would be needed to see or feel surface imperfections. But if the lobe is flat or worn, bad follower, you'll know by only removing the valve cover and measuring. Overhead cam failures are usually pretty easy to spot without disassembly.
    Justrucking2 and mhyn Thank this.
  10. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    How many miles? Do you idle alot?
  11. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    Remove injector #4 and do a compression test and see what happens
