Injector change
Discussion in 'Ask An Owner Operator' started by Groceries, Nov 27, 2021.
  1. Groceries
    Groceries Bobtail Member
    5
    Sep 22, 2019
    2018 KW Cummins X15 Performance series. Had the check engine light come on and the code misfire #6 cylinder. Changed #6 injector. Do you have to program the new injector ? I have a thumping sound through the air filters. Replaced the injector and had the valves adjusted. There was 1 to loose and 2 to tight. The code went inactive and had it cleared. Drove it about 1 hour everything seams fine. Any clue what the thumping noise is ?
  3. Goodysnap
    Goodysnap Road Train Member
    3,748
    9,115
    Jul 12, 2017
    Injector does not require programming. There is a fuel injector reset prompt under ECM diagnostic tests that tells the ECM you installed a new injector. Only reset the injector you replaced.
    Don’t have anything for you on the thump noise. I’m a lot better at it in person.
  4. Groceries
    5
    Sep 22, 2019
  5. Groceries
    5
    Sep 22, 2019
    Can it be ran until I can have it hooked up to a computer ?
  6. Goodysnap
    3,748
    9,115
    Jul 12, 2017
    yea, it will be ok.
  7. Groceries
    5
    Sep 22, 2019
    Thank you for the information !
    Goodysnap Thanks this.
