Injector help
Discussion in 'Volvo Forum' started by bob32racing, Mar 2, 2017.
  1. bob32racing
    bob32racing Bobtail Member
    5
    Feb 23, 2017
    I suspect a bad injector. I did a temp gun test on the manifold. The front cylinder was 200 degrees warmer than the rest. Ive heard of dead injectors being colder. Any reason why one hole is 200degrees hotter? Stuck injector?
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    I dont trust a heat check of manifold to diagnose an injector. The best way is do a cut out test on individual injectors while the engine is working, under load, pulling, etc. And read the flow results.
  4. bob32racing
    5
    Feb 23, 2017
    I had pulled the connector while running, the engine smoothed out. Plug that injector back in and it misses. This only happens when the engines warm. Still i should not be 200 degrees hotter than any other cylinder.
    KB3MMX Thanks this.
  5. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
  6. bob32racing
    5
    Feb 23, 2017
    I ordered a new one today. Hopefully it fixes the problem.
  7. sbaumann14
    sbaumann14 Road Train Member
    1,238
    1,434
    Sep 1, 2010
    Rhinelander, WI
    VCAD on a cold engine. do a cylinder balancing test
