injector setting
Discussion in 'Freightliner Forum' started by ronnieblueshirt58, Jan 10, 2017.
  1. ronnieblueshirt58
    ronnieblueshirt58 Bobtail Member
    I need the injector setting for cummins 11542987. I've been getting the run around from the company for days.
  3. RocketyMan
    RocketyMan Medium Load Member
    554
    339
    Jun 5, 2015
    ISX, ISB, ISC? What are we talking about here?
    Are you talking about injector codes? Those are usually programmed in the ECM and calibrated per injector. You need the injector serial # per injector and Cummins Insight to program the ECM. And you gotta give more information on your setup. Nobody here is a magic genie and knows your exact setup.
  4. ronnieblueshirt58
  5. ronnieblueshirt58
    It's a 89 855 with oil controlled injector, need to know what are the injectors set at? Thank you
  6. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    RocketyMan Thanks this.
