Injectors on 03 ISX
Discussion in 'Trucks [ Eighteen Wheelers ]' started by colorado18spd, Jan 9, 2016.
  1. colorado18spd
    colorado18spd Medium Load Member
    396
    298
    Mar 10, 2013
    I know for sure that the actuators are bad should I just replace the injectors? Truck has close to a million on the clock. Thanks
  3. 062
    062 Road Train Member
    6,242
    33,602
    Oct 20, 2013
    Have you done a cut out or leak down test?
    How long do you plan to keep truck?
  4. colorado18spd
    396
    298
    Mar 10, 2013
    Have not done a leak down, was told by the mechanic they are bad. Might keep it for a couple of years
  5. 062
    6,242
    33,602
    Oct 20, 2013
    Between actuators and a six pack,that's a big chunk of change.
  6. Dakota1358
    Dakota1358 Medium Load Member
    431
    502
    Jun 15, 2009
    Staunton,Va
    I would find out for sure if they are bad.As mentioned above after the actuators new injectors are getting pricey
  7. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    Do the actuators first then the injectors as needed. Just my $0.02...
  8. colorado18spd
    396
    298
    Mar 10, 2013
  9. taxihacker66
    taxihacker66 Road Train Member
    1,344
    1,224
    Feb 26, 2012
    Concrete jungle.
    6,242
    33,602
    Oct 20, 2013
    Starts out as a rough or surging idle,if really bad you'll have a fuel knock.
    Check out rawze.com for the test procedure.
    taxihacker66 Thanks this.
