Inlet NOX sensor help ..
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Trucker2091, Dec 14, 2020.
  1. Trucker2091
    Trucker2091 Bobtail Member
    Dec 14, 2020
    I have a 2015 Freightliner Cascadia .. I have an active fault code Spn 3216 fmi 13. I’ve searched online and all the information I’m able to come up with is that there is no signal from the inlet nox sensor. I installed a new inlet sensor and the code is still active. Could the new sensor be defective? Any suggestion or info would be appreciated. Thanks.
  3. AModelCat
    164,925
    FMI 13 typically refers to a component being out of calibration, not component not responding.
  4. Trucker2091
    Dec 14, 2020
    Thank you for the reply. Any suggestions as far as what I need to try next ?
  5. Diesel Dave
    9,716
    33,178
    Jan 20, 2010
    Hesperia, Ca.
    I just replaced mine on a 2014 Pete. They did a forced Regen and clear it.
  6. Trucker2091
    Dec 14, 2020
    Thank you for the reply I will give that a try.
    Diesel Dave Thanks this.
