Inspections/ NASTC prepass
Discussion in 'Ask An Owner Operator' started by Dino soar, Dec 30, 2019.
  1. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    I was talking to NASTC today and the person told me a few things I'm curious about.
    He told me that since I have a new Authority I have no inspection I have no points basically I have a perfectly clean record.
    He said that because of that I will almost always get a green light.
    He also told me that I need to try to avoid being inspected at all costs. He was trying to say that if an owner operator gets a bad inspection so many more good inspections are required to make up for that, and it's much easier for larger Fleets with more trucks to make that up.
    I thought that I read somewhere that at some point you want to be inspected. I thought that at some point it's important that you have the inspection on your record. He seemed to not feel that way.
    It was an interesting conversation, but I'm not sure that information is correct.
    What do you think?
  3. kemosabi49
    10,992
    47,974
    Jan 13, 2013
    SW Arkansas
    If you get inspected and they find, say an OOS tire, then your carrier CSA will show a vehicle OOS of 100%. In that case the only thing that will change it is to get clean, or at least non OOS inspections to get the % down. All you really can do is keep your equipment in a condition that you are confident will pass and don't stress on getting inspected. Because sooner or later you probably will.
    tank4life, Dino soar and mhyn Thank this.
  4. 062
    062 Road Train Member
    6,346
    34,009
    Oct 20, 2013
    I would say that green light part is false. Because you have zero inspections you’ll be more likely to be pulled in.
    @RedForeman posted around here somewhere that because of no recent inspections they were getting the red light more.
    PE_T, Dino soar and mhyn Thank this.
  5. TallJoe
    TallJoe Road Train Member
    7,490
    16,273
    Apr 12, 2016
    Chicagoland
    A few weeks ago, I was pulled over for a random level 2. In the last 3 years, since I started as own authority, I had a total of 4 inspections (2 of them level 2, and 2 level 3 : paperwork only) All of them were clean without any violations discovered. This time, the DOT cop printed my company report showing my CSA as 70 which is not good at all. He told me that my record shows insufficient data and that I need more inspections, including level 1 to better the score.
    So, some inspections are needed in order to keep the rating score favorable.
    Having said that, I am not going to volunteer for inspections at DOT scales, unless the insurance will make it a condition of some sort.
    Dino soar Thanks this.
  6. GraniteRiver
    GraniteRiver Light Load Member
    208
    285
    Apr 22, 2018
    In the last year I can count on one hand how many reds I’ve received and those were either when I was near gross or when they were calling everyone in.
  7. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Back when my authority was new, a couple of times I was told, I was pulled in because my number was not that old. I generally got a clean inspection and a sticker. I am also bad about asking for an inspection and driving to the scales to get it, that way I generally get a sticker and here they will not mess with you for 90 days usually when you get it.
    They run your numbers here everytime you cross the scales and know exactly when you had your last inspection, and do not mess with you for a certain amount of time anyway, sticker or not though.
  8. stayinback
    stayinback Road Train Member
    3,911
    8,257
    Jan 24, 2014
    chicago,il
    This reminds me.......
    I Gotta get back up there to Fair Haven,VT Scale
    That Little Freckled Redhead Ms.Genevieve Paul, Im Gonna bring her a Dozen Roses,Then Whip Her ### into Submission......Bad Girl put me OOS Because She didn't like paper Logs and I didn't have last 8..
    If any of you VT scale hound read this- Im Coming.......Ms.Paul was so Cute.....Im gonna spank her butt good.
    Big_D409 Thanks this.
