So i recently installed a new Cobra 29LX into my truck with a Firestik 2 antenna. It is installed and working however when i went to tune it it wouldn't change so i figured I had a Bad Ground on the antenna. I checked the ground and it was intact not grounded very well so i tried everything to get a good ground from grounding the mount right to the frame and i can't get anything to work. I took booster cables and put them from the mount to the frame and it grounded perfect so i figured it was my ground cable, So i took the booster cable attached it to the end of the ground wire and to the frame and it worked perfect. This confused the heck out of me as i hooked the ground wire back up and it will not work. If anyone could give me any pointers as to what could be causing this problem i would greatly appreciate it as I am getting very frustrated with it.
