Installing an EasyJake in 2011 Cascadia
Discussion in 'Freightliner Forum' started by 206airmail, Sep 29, 2018.
  1. 206airmail
    206airmail Bobtail Member
    10
    Jul 31, 2018
    Hi all, I'm wanting to install an EasyJake in my 2011 Cascadia. However, I'm not sure exactly where to wire into the engine break system at, as all I have is the steering wheel button for the engine break. Not an actual switch on the dash.
    I was wondering if anyone has any knowledge on how to wire it in? I've put them in several Kenworths, but always had a switch in the dash to tie into.
    If it matters I have a DD15
    For anyone interested here is the link to there website
    EasyJake | Operate your engine brake more easily
  3. Hulld
    Hulld Road Train Member
    2,884
    6,567
    Oct 19, 2015
    Upstate NY
    I have one installed in my 2007 Columbia.
    I installed mine in series with the clutch pedal switch.
    So in essence when you throw the easy Jake switch on it breaks the circuit on the clutch switch and shuts the Jake off.
    Hooking it up this way also had another great unintended benefit.
    If you need to cancel you cruise control quickly just throw the easy Jake switch and the cruise is off and then turn it back on and your Jake is on (as long as your dash or steering wheel main switch is on)
    I also mounted mine the other way around so it’s a thumb operated and not pinky.
    KB3MMX Thanks this.
  4. 206airmail
    10
    Jul 31, 2018
    Hadn't thought about that. Might end up having to do that if I can't figure out where the actual wire going to the switch is.
    I prefer to be able to have my Jake's on while I have my cruise set though.
    Thanks for the idea though, might end up having to go with it.
  5. Hulld
    2,884
    6,567
    Oct 19, 2015
    Upstate NY
    You missed the point your jake DOES work when cruise is on.
    Mine jake actually works progressively when the cruise is on.
    KB3MMX and bzinger Thank this.
  6. 206airmail
    10
    Jul 31, 2018
    Ah ok, I did misunderstand you. That actually is a good idea! Thanks!
    Hulld Thanks this.
  7. Hulld
    2,884
    6,567
    Oct 19, 2015
    Upstate NY
    Yes
    Wiring it the way I did everything works exactly the way it did originally only now you have an extra switch (the easy jake) that can turn off both the jake and the cruise control.
  8. grindemgone
    grindemgone Bobtail Member
    How did you wire your Easy Jake to your clutch switch?
    I have a 07 Columbia as well.
    I noticed there are 3 wires coming off of the swich.
    Did you splice into on of the wires?
  9. uncleal13
    uncleal13 Road Train Member
    3,797
    6,296
    Apr 9, 2009
    Humboldt, Sk
    Cascadia has coded J1939 switches, you cannot just wire in any old switch.
  10. Hulld
    2,884
    6,567
    Oct 19, 2015
    Upstate NY
    I marked the wires in reference to the switch and then in did them.
    I then used an ohm meter and found the terminals on the switch that open and close with clutch activation and wired it in there.
    THE RUSTY and KB3MMX Thank this.
  11. Hulld
    2,884
    6,567
    Oct 19, 2015
    Upstate NY
    You can still wire it in the clutch switch.
    When activated the truck computer thinks you pushed the clutch in.
    The computer is programmed to turn the jake off when you step on the clutch.
    That is also why when activated it cancels the cruise control.
    In essence the switch does not turn the jake off but tricks the computer on the truck to turn it off for you.
    KB3MMX and uncleal13 Thank this.
