Installing Series 60 on Freightliner Cascadia
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 4rdtruck, Mar 17, 2018.
  1. 4rdtruck
    4rdtruck Bobtail Member
    27
    7
    Nov 19, 2014
    Hey folks,
    Did any of you installed a Series 60 engine in a Freightliner Cascadia, or did you hear any friends installing it ? My DD15 engine died and it will cost me 30-35k to overhaul it witch is ridiculously expensive. My local shop told me that is possible, I'll need a special harness kit, plus some modifications in the hvac and cooling system, mounting brackets, but I want to hear more opinions.
    Much appreciated.
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Sure anything is possible with time and money.
    I can see a lot of shop labour $$$$$$ , down time $$$$$$, and the cost of a reman $$$$$$ being not far off your $30-35 original quote to just fix your dd15.
    If your going to do the swap it would only make sense to put a fresh S60 in there.
    mhyn Thanks this.
  4. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    Fix the motor, and learn the emission systems. More than likely that is what killed your motor. Just a guess on my part, the emissions killing the motor.
  5. Bean Jr.
    Bean Jr. Road Train Member
    5,573
    9,929
    Mar 30, 2014
    It is against epa regulations to change the engine to one with different emissions controls. If your Cascadia has dpf, perhaps the ecm of a series 60 wouldn't support it.
    D.Tibbitt Thanks this.
  6. ChicagoJohn
    ChicagoJohn Road Train Member
    2,390
    2,755
    Jan 14, 2016
    Chicago
    Do a search for wire harness, someone in AZ makes a conversion harness. Harrison Freightliner sells cascadia gliders with series 60's, so yes it can be done, but I'm not sure how much you'll actually save. A crate 60 runs about $23,000.
  7. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    If someone's charging $30k-35k to have it inframed, you're getting ripped off.
    If you're close to the Fontana, CA area, a shop I go to can inframe it for about $14k.
    He inframed @dztruck DD15 Cascadia last year, and the motor is working fine.
    Where is the truck located at?
    Bean Jr. Thanks this.
  8. 4rdtruck
    27
    7
    Nov 19, 2014
    That was the estimate at the dealership. Plus there are different levels of rebuilding a motor so the price varies accordingly.
  9. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    The S60 was a factory option in 08 , it can be done .
  10. 4rdtruck
    27
    7
    Nov 19, 2014
    I didn't know anything about EPA regulations, I'll look more into them. That sucks. In my point of view all the glider manufacturers are not abiding EPA regulations then.
  11. sdaniel
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    Glider is not a new truck , it is a replacement part .
