Instrument Lights
Discussion in 'Trucks [ Eighteen Wheelers ]' started by colorado18spd, Apr 19, 2016.
  1. colorado18spd
    colorado18spd Medium Load Member
    396
    298
    Mar 10, 2013
    They won't go out and if I hook up to a trailer marker lights stay on too. What gives?
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    Find the marker light relay and swap it with another one to see if it's stuck.
  4. colorado18spd
    396
    298
    Mar 10, 2013
  5. JAYRODPA
    JAYRODPA Light Load Member
    157
    109
    Dingmans Ferry pa
    you should be able to hear the relay click on and off with the light switch. check the relay box cover. most trucks will have spares. if not swap it out with one you wont need right away.
  6. colorado18spd
    396
    298
    Mar 10, 2013
    I just took the 10amp fuse out of the inst cluster, put a new in, it starts beeping, no fix yet, it is clicking, from the fuse though not a relay.
  7. AModelCat
    164,920
    Sounds like either a stuck relay or you have a short to power somewhere. Start with the easy stuff like relay swap first.
    My question to you: are your tractor marker lights stuck on all the time as well or is it just dash lighting?
  8. colorado18spd
    396
    298
    Mar 10, 2013
  9. colorado18spd
    396
    298
    Mar 10, 2013
    Guess I'll pull the fuse when I park it.
  10. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Yes, I agree. Short to power. I would start with some easy stuff. Open up the dash panels and jiggle all the wires around. Chances are the short is outside. Do the same with someone inside watching the lights. If wires go into a box on your rear light rack pull and jiggle the harness going in. Look under the hood and try them there also.
  11. colorado18spd
    396
    298
    Mar 10, 2013
