Interior accessories dont turn off
Discussion in 'Peterbilt Forum' started by Bos Extreme Trucking, Jan 2, 2020.
  1. Bos Extreme Trucking
    Bos Extreme Trucking Bobtail Member
    5
    Im working on a 97 2ws 379 that when the key is shut off the interior accessories act as if the key is still on (the blower motor will still run, the oil and air brake light stay on, and the volts & amps read still). There is obviously a short some where, but I have not diagnosed where yet. If anyone has a diagram that would help please reach out.
    Thanks in advance,
    BOS Diesel Shop
  3. FdEF
    FdEF Light Load Member
    70
    57
    Dec 5, 2017
    Ogden, Ut
    Obvious place to start would be the key switch
  4. Ridgeline
    22,720
    123,335
    If you are a shop then you know how the relay system works on those years of trucks, maybe a stuck relay could be a cause of it.
  5. Bos Extreme Trucking
    5
    Thanks to both of you. Thats where I figured to check first.
