Intermittent air pressure drop at red light.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jeffman164, Oct 10, 2025.
  1. jeffman164
    jeffman164 Medium Load Member
    630
    587
    Dec 4, 2012
    1999 International 9200 - 12.7 Detroit. I will have intermittent air pressure drop when applying brakes at red light. It will drop sometimes so much that the buzzer will go off. I apply the parking brake and pressure will rise and hold pressure. Other times at red light, pressure will stay up 110-120. Very intermittent. Murphy's law kicks in when trying to check under truck while someone is in cab holding brake peddle. Always holds pressure. Murphy is a bad mo fo sometimes. Any ideas of what to check ?
    Deezl Smoke Thanks this.
  3. xsetra
    xsetra Road Train Member
    5,198
    7,149
    Aug 21, 2011
    When losing air pressure, do you hear the leak?
    Same problem if you disconnect trailer?
    My guess? Brake chamber pancake seal.
  4. Deezl Smoke
    Deezl Smoke Medium Load Member
    540
    356
    Feb 12, 2011
    Hillsboro Oregon
    I'm going to go with a relay valve. ? It sounds like it is sending air out the exhaust port.
    Star Rider Thanks this.
  5. Heavyd
    Heavyd Road Train Member
    7,828
    6,277
    Feb 4, 2009
    With or without a trailer?
    Standard air brake diagram below.
    Anything on the service side, primary or secondary can be leaking.
    Treadle valves, relays valves, tractor protection valve can all leak intermittently as the exhaust port will seal one time, then not the next.
    Brake chambers can also leak intermittently, such as the center seal between spring brake and service side.
    Also, it may just be a coincidence that you are stopped when this happens. Could also be the purge valve at the bottom of the dryer is sticking open and the outlet check valve is also stuck open to allow air to back flow.
    One way or the other, from the amount you are losing, it should be easy to find once it rears its ugly head!
  6. jeffman164
    630
    587
    Dec 4, 2012
    Without a trailer. When I find it , I will post it. Thank you for responses.
    Heavyd Thanks this.
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    I am going with xsetra: The regular driver complained about rapid air loss and brakes locking down for several weeks. Local truck that only went to land fill and had been checked at the shop many times. I left the shop with it after a full inspection and service. About the time I shifted to high range air pressure was dropping rapidly and parking brakes were applying. I jumped out and found a chamber dumping air, then the brakes set. Got in the truck, and air built back up, went to the shop and no leaks.
    Never saw or heard of anything else that could lose that much air that fast and then work OK for 3 days.
    Service brake, parking brake, truck, trailer and how do you test that? Do not get rolled over. One I was driving had no trailer. I turned it off and left it in gear.
    Heavyd, Oxbow and Star Rider Thank this.
  8. Star Rider
    Star Rider Road Train Member
    1,790
    18,713
    Sep 23, 2019
    A piece of debris like a small pebble in a QR valve could cause this.
    Hit the brakes the pebble or whatever moves and holds the valve open.
    Got the t-shirt for that one.
    Heavyd, BoxCarKidd and Oxbow Thank this.
  9. NightWind
    NightWind Road Train Member
    2,718
    19,173
    Nov 11, 2006
    Sunny South, AL
    I would look at brake chambers both truck and trailer and air bags too. I chase air leaks tiny ones true all the time drives me nuts
  10. jeffman164
    630
    587
    Dec 4, 2012
    Turned out to be a bad brake chamber. Sporadic problems drive me a little crazy sometimes. Thank you for responses.
  11. Deezl Smoke
    540
    356
    Feb 12, 2011
    Hillsboro Oregon
    Glad you found it. Thank you for the update on the repair. Updating when the fix is found, really helps the forum.
    Heavyd Thanks this.
