Intermittent power loss 2012 d13 engine 12 sp auto
Discussion in 'Volvo Forum' started by southbaydad, Aug 25, 2019.
  1. rlsmith631969
    rlsmith631969 Bobtail Member
    Did you happen to find the problem? I have a 2012 D13 with I shift doing the same thing. I was told by dealer to check the ground about 4 inches up from the accelerator pedal. Those were tight but I loosened them, moved the wires around then tightened back up. I have had the TCS, ABS, & hill assist light come on and go off with no issues until today. Any help from anyone else would be greatly appreciated. My other truck is down from an error on the preview mechanic I used. 46000 miles on an inframe and it spun a rod bearing due to not being torqued down. I can't afford for this to go down too. Thanks truckers and mechanics for any help.
  2. Snowman55372
    Snowman55372 Bobtail Member
    8
    6
    Jan 26, 2021
    I think that’s the same think that’s going on with my Volvo D13. Putting in a new actuator tomorrow. Keeping fingers crossed
  3. Brandon h sr
    Brandon h sr Bobtail Member
    I have the tcs eco roll and abs light on if I smack the dash it will go away and my truck will drive normal how do I fix
  4. gekko1323
    gekko1323 Road Train Member
    1,672
    2,788
    Jul 14, 2018
    Henderson, NV
    Where are you located? Do you work on the Series 60?
  5. Brandon h sr
    I didn’t replace anything I’m
    Asking what was done on the databus to fix the issue
