Intermodal in Chicagoland
Discussion in 'Intermodal Trucking Forum' started by RERM, Sep 26, 2014.
  1. RERM
    RERM Road Train Member
    1,683
    1,125
    Dec 13, 2012
    Chicago, IL
    Just started running Intermodal in Chicago, so far so good, everything is as advertised (the chassis are POS), but I do like the runs and the hometime, pay is competitive...the experienced drivers here should maybe post some advice (ex.... how to check out the chassis before running it), hints and tips (any good alternate routes into and out of the rail yards (Global I, II, III and IV, Yardcenter, CSX, etc....).....Currently I'm running Chicago to Louisville or Columbus, IN.....any good alternate routes (to I65)?.....
  3. Ebola Guy
    Ebola Guy Heavy Load Member
    977
    789
    Oct 11, 2009
    Manitowoc, WI
    Welcome to the club and soon you will find navigating in and around the rails in Chicago a breeze.
    The only CSXs I go to are Bedford Park and 59th St, both are relatively straight shots to get to, meaning no worthwhile shortcuts.
  4. RERM
    1,683
    1,125
    Dec 13, 2012
    Chicago, IL
    Had my first tire blowout on a trailer by the 240 on I65 yesterday.....pos trailer tires.....
  5. JJKid
    JJKid Medium Load Member
    690
    513
    Aug 17, 2014
    Chicago, IL
    Purchase an Air-gauge and check your tires in your pretrip. You'll decrease the chances of having a blow out alot.
    Also welcome to Intermodal. I run those rails as listed in your OP.. but I primarily go to CN Harvey, CSX, NS,BNSF Elwood, Intergrated Harvey here and there.. and yard center. All operate just about the same. Routes? not really. And those chassis... all crap!
  6. Winbot
    Winbot Light Load Member
    59
    28
    Apr 16, 2014
    As far as pretrips go I would say always look at the FMCSA first, the closer to expiration it is the more thorough you need to be. I dont mean to say if the thing just got inspected that you don't need to pretrip it, but if it's a month away from expiration go over the #### thing with a fine tooth comb. You should at the very least be thumping your tires, checking your lights and doing your fan down. The FMCSA check can be done from the cab as well so if you're in search of an empty try to get one that is on a chassis that has recently been inspected.
    Ebola Guy and RERM Thank this.
  7. Ebola Guy
    977
    789
    Oct 11, 2009
    Manitowoc, WI
    I'd rather hook up to a less than stellar box on a good chassis than a brand new box on a less than stellar chassis.
    Cody1984 and RERM Thank this.
  8. JJKid
    690
    513
    Aug 17, 2014
    Chicago, IL
    Thanks for bringing up the FMSCA inspection on chassis.
    If ya pull a chassis that has an expired inspection and you got pulled over or pulled in to a scale and given an inspection, you'll be nailed personally a $127 ticket for an expired fmsca inspection on a chassis. Yep. Happened to me once, tried to get safety to pay it lol. I fully knew well it was my fault, was just in a rush and forgot to check it... but safety response was "yeah really? might aswell pay you for coming to work too!" lol. #######! lol.
  9. RERM
    1,683
    1,125
    Dec 13, 2012
    Chicago, IL
    Those tube tires, what air pressure should I be looking for? 100 or 85psi?
  10. Cody1984
    Cody1984 Medium Load Member
    419
    249
    Jan 24, 2014
    PA
    I rarely check the air pressure in the tires on the chassis. It's ultra rare to see anyone whip out a tire pressure gauge in the rail yard and check the pressure on the chassis tires. I do it on my tractor but on a chassis I'm usually hooked to 6 or more a day...I've been hooked up to 14 before in one day. It gets a kick test to see if it's flat or not. I'm a company driver for JB Hunt and they have been putting the auto inflation system on there chassis which helps a lot in this regard. Although the whole low air warning sound they give off when a tire/s is low on air is rather annoying. When I check the tires I'm checking to see if they are flat or not and if they aren't flat if they are damaged and need replaced. If not I take it down the road. As far as the rest of the pretrip goes you check everything and you report every bit of damage as well. The left mudflap bracket bar is bent out 2 inches you report that is damaged, the right front corner post is bent by 3 inches you report that as damaged, container buckled somewhat because of the way the packer loaded or unloaded it you report the side paneling is bent in. If they tell you "we only write up damage if it's six inches or more" you tell them it's more then 6 inches even if it's 3 inches and if the registration box is missing along with the chassis registration or if the registration is just missing you get a chassis swap period.
