International 4200 with a VT365 cold start problem
Discussion in 'International Forum' started by trent001, Jan 6, 2021.
  1. trent001
    trent001 Bobtail Member
    6
    Jan 6, 2021
    I have an RV that is on an International 4200 chassis. The motor is a VT365. The problem i am having is hard starts when cold. If I do not plug the block heater on for an hour or two it takes about 30-45 seconds of cranking to get the engine to start with LOTS of white smoke while cranking. When the block heater is plugged in it will fire right up. I think I am loosing the high pressure oil somewhere. Dummy plug, stand pipe, HPOP, etc...??? Does anyone have any past experience with this or any ideas of where to start?
    @Heavyd ?
  3. trent001
    6
    Jan 6, 2021
  4. Heavyd
    Heavyd Road Train Member
    7,811
    6,264
    Feb 4, 2009
    I would check the glow plug system first. Should be a solenoid for them on the right side valve cover. When cold, it will click on and send power to the glow plugs. Make sure the solenoid is working, has battery power and so on.
    Crude Truckin' and QUALITYTRUCK Thank this.
  5. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,439
    6,807
    Oct 22, 2016
    North Dakota, Eh?
    What weight of oil you running?
  6. trent001
    6
    Jan 6, 2021
    Brand new 15W40 Rotella. I live in Southern CA so freezing temps I do not worry about, but it does get down to around 40 degrees currently.
    Crude Truckin' Thanks this.
  7. Crude Truckin'
    2,439
    6,807
    Oct 22, 2016
    North Dakota, Eh?
    I'd try Rotella T6 next change.
