International 4300 ,2017
Discussion in 'International Forum' started by Douzmoll, Nov 20, 2024.
  1. Douzmoll
    Douzmoll Bobtail Member
    Hello, i need help please. Next to my mileage reading i see "warning engine". I brought to 3 shops, they said nothing wrong with my truck. I drove it as it is for months still running great. I did the maintenance also but the sign still bothered me, help please.
  3. Ridgeline
    22,724
    123,397
    Did you bring it to an international dealer or joe-bobs diesel fixum shop?
    Heavyd Thanks this.
  4. Douzmoll
    No, where Joe Bobs located? International dealer might be much more expensive, i guess. I brought it to Truck Rush Center though.
  5. Arctic_fox
    4,510
    25,491
    Sep 16, 2016
    Joe bobs is a snarky colloquial term refering to independant shops of dubious ability. Also dont goto rush. Most of those idiots couldn't fix a sandwhich god forbid a truck. Dealers do cost more but as a general rule are going to be the absolute best at fixing their own brand of truck. Not always granted. But 9 times out of 10 a dealer will do a better job then an indie shop.
    Heavyd Thanks this.
  6. Inderjit
    Inderjit Heavy Load Member
    770
    735
    Sep 17, 2017
    I have seen that before with a few 4000 and 7000 series. Sometimes "water in fuel" "low washer fluid" and "warning engine".
    Does the message stay on all the time or is it intermittent? Id the engine warning lights in the instrument panel are out and there are no fault codes I would ignore the message.
    Heavyd Thanks this.
  7. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Like mentioned, sometimes the message gets stuck in the cluster. The cluster may simply need a reboot because it is one of the few modules that never completely powers down at key off. Locate your cluster "BAT" fuse and remove it for 30 seconds, reinstall. See if that works.
    QUALITYTRUCK Thanks this.
  8. AModelCat
    164,720
    If you want help you're gonna have to provide a lot more detail than what you have. What did the other shops check, what fault codes did they find, what is the truck doing/not doing?
    QUALITYTRUCK and Heavyd Thank this.
