International 4300 DT466 Battery issues !
Discussion in 'International Forum' started by Skatulaki, Dec 8, 2020.
  1. Skatulaki
    Skatulaki Bobtail Member
    4
    Dec 7, 2020
    What does this truck require for Batteries, and alternator! The company I work for, does everything on the cheap, and the people in charge do not really know ( expletive ) about repair work. They have been screwing around with this truck for a while, mostly jumpstarting it when they need to use it, and then blaming the drivers for leaving the key on as excuse for Batts being dead. I haven't been there long but since I'm the only one in the shop with Electrical education, and 30 years working on copy machines
    I told the boss that I can fix the problem. He looked at me like I was stupid. I said the connections are horrible, the whole mess needs to be taken apart and cleaned, the batteries checked ( even though less
    than a year old ) charged up and checked to make sure they can hold a charge. Later he told me go ahead, do what you you think you gotta do. So I did, Pulled the batts, cleaned the poles, put a meter on them 12 volts on one, 11 on the other. Told him they gotta be 13V . Put them on the 100 Amp fast charge. In the meantime I cleaned all other connections. However neither batt recovered. So I told him
    Batts probably no longer any good, and since they are dated Feb 2020 take them back to Interstate. Then I told him, look you cant just toss a couple good batteries in there and expect it to work. You have to meet the power requirements of the vehicle. Its going to need batteries with required Amps, and an alternator
    capable of keeping them charged. And we have the additional problem of all the "added equipment"
    thats been "rigged in" and whether or not that its causing a drain. ( which it likely is ). I said I can fix this,
    but not in 15 minutes, or even a day. I have to do some research.
    SO ! My questions are ? How many ? and of what capacity of Batts do these trucks require? Current wiring configuration is for two Batts, I've seen pics with 3. And What Amp Alternator is required?
    Also , I should state that the truck is used a "Crash Truck" or "Attenuator Truck" for Highway
    maintainence , in case that makes a difference.
    Thanks in advance !
  3. AModelCat
    165,057
    A 466 is tiny. Two batteries should be sufficient. They're only there for starting. What's the current alternator rated at? More than likely I'd just get it bench tested and if its producing, put it back on.
    The symptoms you're describing are classic parasitic draw. There's something on the truck that is constantly powered up. You just need to find out what it is.
    Skatulaki and Hulld Thank this.
  4. pavrom
    pavrom Road Train Member
    3,223
    7,459
    Apr 29, 2012
    NE illinois
    Call the dealer , he will tell you all you need to know
  5. Flint1
    Flint1 Road Train Member
    1,163
    9,949
    Sep 4, 2019
    Alberta
    There is a bazillion school buses running around with dt466s. Most have 2 or 3 group 31 batteries. Consider installing a battery disconnect switch.
    Still have the human factor with a shut off switch tho...
    Skatulaki Thanks this.
  6. Hulld
    Hulld Road Train Member
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    Most likely a parasitic drain issue.
    Although it could be an issue with the truck it’s self I always start by a good inspection of any aftermarket equipment wired in to the OEM system of the truck.
    I have found over the years that generally aftermarket upfiters do a very poor job of connecting to oem Wiring harnesses causing many corrosion electrical issues.
    You can run a parasitic drain test by disconnecting the positive battery cable and putting an amp meter in series between the cable and the battery post.
    Make sure everything electrical is turned off in the truck when you run the test.
    I would say if you have more than about .75 amps you have a drain issue.
    If you don’t have an amp meter you can get a general idea if there is a problem by using an old school incandescent bulb style test light.
    Put the test light between the battery and cable just like the amp meter.
    If the test light lights brightly you probably have more than a .75 amp draw.
  7. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    We have the exact same truck, it has a 26 foot box with a liftgate on it and we have three batteries in our truck.
    750 CCA
    baha Thanks this.
  8. Skatulaki
    4
    Dec 7, 2020
    Thanks, I hadn't thought of that, I have a multimeter test meter, so I shouldn't have any problem checking that. Boss got 2 new 950 Amp Batts, that one of the foremen reinstalled the other day.
    I was busy doing the normal part of my job, so I dont know how it turned out yet. The winch that
    is used to raise the "Crash Box" on the back of it, I believe is hard wired to the batteries and has an off and on switch of its own. There is also a breaker at the Batts that I believe is part of that circuit.
    The arrow board is my suspected culprit. The wiring there looks like what a 16 year old would do when wiring a stereo and speakers in his car. In fact they have to unplug one of the wires to get
    the arrow to turn off. So I suspect it is falsely wired into Battery accessory, instead of ignition
    accessory.
    Hulld Thanks this.
  9. Skatulaki
    4
    Dec 7, 2020
    .l..
  10. Skatulaki
    4
    Dec 7, 2020
    That makes sense, the extra battery to run the liftgate motor.
  11. Hulld
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    Do a good inspection of all the aftermarket added accessories, that’s probably where you will find it.
    For reference my 2007 international 4300 DT466 is equipped with just two batteries.
