International 4400
Discussion in 'Expediter and Hot Shot Trucking Forum' started by Eagle River Transport, Oct 30, 2012.
  1. Eagle River Transport
    Eagle River Transport Bobtail Member
    24
    Eagle River, Wisc
    Anybody have any experience with running Internationals.
    I'm new going in ...and dont want to start out with the wrong or too small equipt and then have to upgrade later.
    Here's whats on the board so far...
    2006 International 4400 DT550-300hp Diesel- Allison tranny- Western hauler bed..50k miles.
    Trailer is 53ft center rail trailer...haul ..RV's..boats & cars...
    Let me know what you all think...looking forward to hearing from all of you.
    Thank You...
  3. bender
    bender Road Train Member
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    What brand of trailer and axle set up? What kind of money?
  4. TennTrucker
    TennTrucker Light Load Member
    250
    168
    Aug 20, 2010
    Dresden, Tn
    Only complaint I have heard is short life injectors.
    Sent from my DROID X2 using Tapatalk 2
  5. Shaggy76
    Shaggy76 Heavy Load Member
    831
    307
    Feb 22, 2012
    Orlando, FL
    The 03-08 models hav very short injector life spans. They run on a HPO (High Pressure Oil) system, otherwise called HEUIs (Hydraulic actuated, Electronic controlled, Unit Injectors). They have seal leaks, plug leaks on the oil rails, stiction issues, HPOP failures, etc. You have to be on top of your oil changes if you want few issues. If your oil gets too dirty, the injectors will fail every time, mostly due to stiction in the spools of the injectors.
    Keep the oil clean and you should have good life out of the engine.
  6. Eagle River Transport
    24
    Eagle River, Wisc
    So it might be a good idea to invest in a back up set of injectors and have them with me...just as a safeguard.
  7. bender
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    That would be a major investment in itself to buy a set to have setting around just in case. Everyone who starts in this business is positive he will cut a fat hog in the hind end until the reality of operational costs surfaces. Hold on to your maintenance money until you need to spend it. There are too many possibilities of where you might need to apply it.
  8. bender
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    The Intl DT engines had a lot of liner o-ring seal failures and high pressure oil manifold gasket leakage. I fixed a bunch of both on a fleet we serviced.
