I have a 2001 International 4900 I just put a new governor on it and still cannot regulate air pressure it has no air dryer on it so no purge valve that I can see
International 4900 air governor problems
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Greasemonkeygringo, Aug 6, 2019.
Ok, doesn't regulate how? Too high, too low...?
spsauerland Thanks this. -
Was constantly too high I just took it out on the road and won't build pressure now past 60 lb
Unbolt your governor and see what it does. If the original problem returns, then something is wrong the governor you just installed or incorrect plumbing.
Greasemonkeygringo and spsauerland Thank this. -
Have you disconnected the other end of line from the unloading valve, disconnected the discharge hose from the compressor, and run it while applying and removing shop air to see how the compressor responds?
Greasemonkeygringo Thanks this. -
Thank you for your replying ,we only got a couple Internationals in our fleet and my first working on one without a dryer, the learning curve Is never over. Lol
Thank you ,getting ready to pull it in.
