HI GUYS I HAVE A INTERNATIONAL 7400 DT 570 WHEN THE ENGINE WARM IT SHUTS OFF BUT I REPLACED ALL THE INJECTOR ORINGS AND SEALS ON THE OIL RAIL. STARTS PERFECT IDLES LOVELY BUT THE MOMENT THE ENGINE WARMS UP IT SHUTS OFF PLEASE HELP ME GUYS...
International 7400
Discussion in 'International Forum' started by SHAKIR, Aug 30, 2018.
Throwing any codes?
Side note ... Using all capital letters is considered yelling when on a forum. Perfectly okay if you are mad though. -
hahaha sorry i wasnt aware yes it is throwing codes as follows: 112. 115. 312. and 335.
112 is battery voltage too high
115 coolant temp signal out of range high - not temp, but circuit fault
312 oil temp signal out of range high, not temp, but circuit fault
335 ICP unable to build during crank.
I would get your codes cleared and then run it until it shuts off and see what codes come back. If you get no codes, then you have a fuel problem.CraigInReston Thanks this.
