International 7600 vent door problem
Discussion in 'International Forum' started by Mikesuburban1, Dec 31, 2016.
  1. Mikesuburban1
    Mikesuburban1 Bobtail Member
    44
    13
    Dec 30, 2016
    Rockland county ny
    I have a 2007 international 7600 and im having a problem with the vent door motor. Right now its stuck on dash vents but i can move the door by hand i took the motor out and noticed it was broken so i bought a new one and tested it before i installed it and i just spins in one direction 360 degrees then stops and the controles on the dash dont do anything. Has anyone ever had this problem??
  3. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    It has to go through a calibration procedure when you first assemble it. Install the actuator and make sure it is mated with door properly. plug it in. It will re-calibrate automatically if you disconnect power to the HVAC module one way or the other. Usually just disconnect the batteries is the easiest.
    BoxCarKidd Thanks this.
  4. Mikesuburban1
    44
    13
    Dec 30, 2016
    Rockland county ny
    Thanks heavyd it finally works
    Heavyd Thanks this.
