International 9200 gauges question
Discussion in 'International Forum' started by jmjohn, Jul 21, 2025.
  1. jmjohn
    jmjohn Bobtail Member
    Dec 5, 2022
    Hey all, my truck is a '99 International 9200 with the base gauges only. Does anyone know if the wiring harness on these trucks allows you to plug and play sensors into the harness and add some of the other OEM gauges (axle temps, trans temp, pyrometer, etc.)?
    In the gauge cluster itself, the sockets are present for the OEM gauges, they're just empty. I can cut the new holes for them and drop OEM gauges in. Just wondering if there are dummy plugs in the harness or anything for the sending units or if these harnesses were completely different from trucks that had those gauges stock.
  3. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    There will be no wiring or sensors.
    jmjohn Thanks this.
  4. jmjohn
    Dec 5, 2022
    Copy that, thanks. Aftermarket it is :)
