International 9400 bouncing on start
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ninehk, Jan 2, 2021.
  1. ninehk
    ninehk Bobtail Member
    20
    Jun 10, 2020
    My international 9400 is bouncing on starting from stops after I replaced the cab height valve and air bags. Should I find a good adjustment for it or could the problem be elsewhere
  3. AModelCat
    164,704
    Did you change the shocks too?
    How are the front cab mounts?
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    You will need to lower the air bags a bit at a time with the adj. rod, till you get it like it was before you put all the new parts on it?
  5. 201
    201 Road Train Member
    12,787
    26,309
    Apr 16, 2014
    high plains colorado
    Flywheel is warped.
  6. ninehk
    20
    Jun 10, 2020
    Front cab mounts are about 4 months old. I’m going to lower it little by little see if that helps I’m hoping it isn’t the clutch
  7. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Start in a lower gear
    Heavyd and AModelCat Thank this.
  8. ninehk
    20
    Jun 10, 2020
    It does the same thing wether I start in first second or third
    uncleal13 Thanks this.
