International 9400 Rear Tail Light
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by LeviTrucker, Dec 12, 2024.
  1. LeviTrucker
    LeviTrucker Bobtail Member
    34
    5
    Mar 24, 2022
    I’m having issues with my tractor marker lights. All the lights light up except the rear right side tail light stays solid. Also when I put my 4 ways on they flash and other times they stay solid. I’ve changed the parking break valve, all air pressure switches, the blinker indicator module, all new relays, and have changed all lights on the outside including the rear light that stays solid. If anyone knows how to fix this or what it could be, please let me know.
  3. 062
    062 Road Train Member
    6,356
    34,060
    Oct 20, 2013
    Possibly a rubbed wire or corrosion inside a plug letting voltage through.
    @Heavyd
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,567
    6,655
    Aug 26, 2014
    I do not know but when you transfer from running and or head lights to turn signals the problem is often where you have a bad or dim light. Does the right tail light wiring junction in the left tail light?
    Regardless of any of that disconnect all of the wiring harness plugs you can along the way. If a disconnect stops the turn signal flashing the marker lights you know which way to search.
    Often bad grounds but they will not cause a light to stay on.
    A more in depth description might help.
    Now we have chassis control modules and such but I thank you are bit older than that.
  5. Heavyd
    Heavyd Road Train Member
    7,831
    6,282
    Feb 4, 2009
    What is the last 8 of you VIN?
  6. LeviTrucker
    34
    5
    Mar 24, 2022
    3C078182
  7. LeviTrucker
    34
    5
    Mar 24, 2022
    With all marker lights off or on, if I use either blinker or hazards it stays solids and cuts in and out. Other times it works fine this situation is really testing with me at this point.
    BoxCarKidd Thanks this.
  8. Heavyd
    7,831
    6,282
    Feb 4, 2009
    I am suspecting you are getting tail light power shorting to the brake/turn light circuit and this is why it is staying on. Start testing by leaving the lights turned off and only the hazards on. Is the tail light staying on solid with just the hazards on only?
    062 Thanks this.
  9. LeviTrucker
    34
    5
    Mar 24, 2022
    With all lights off the hazards on it doesn’t stay solid which is weird..When I turn on all lights the right side stays solid. Today I noticed when I press the breaks, my right light indicator would turn on the dash. Also at times when I turn my lights on in general the right light indicator on the dash will illuminate and stay solid then eventually goes away. My last 8 are 3C078182 where should I be looking ?
  10. Heavyd
    7,831
    6,282
    Feb 4, 2009
    For the right turn indicator, if that light is on when you have the brakes pressed, take out the right turn relay. If the light is still on, then something back feeding from the trailer socket feed circuits somewhere. This may affect your tail lights too. For your turn light issue, make sure you have a good ground connection with your lights back there. If they aren't the plain factory lights, and they have been rewired for custom lights, this makes everything even more complicated for obvious reasons. Disconnect the lights one at a time to see if the problem stops. Try switching lights side to side in case one is internally shorting.
