International Boost Control Solenoid Open Circuit
Discussion in 'International Forum' started by qmckay, Aug 26, 2019.
  1. qmckay
    qmckay Bobtail Member
    4
    I have a 2010 International Prostar+ with the fault codes fault code 1256, spn 7312, fmi 5 . It has low power up hills but check engine light is not on. Can someone help me please. Thanks
  3. cncking2000
    cncking2000 Light Load Member
    135
    217
    Dec 5, 2018
    Without a functioning boost controller, the engine will not be able to build enough turbo pressure to make hills manageable.
    With an open circuit fault, either the solenoid itself has failed, or the wiring to the solenoid has become severed.
    May be as easy as identifying the boost control solenoid and reseating (unplug, and reconnect) the connector to the sensor.
    May have a broken wire in the harness on the other hand..
  4. HillbillyDeluxeTruck
    5,959
    30,497
    Mar 3, 2013
    San Antone
    You might wanna start by telling us what engine, but Im already suspecting its the Junkforce.
    Heavyd Thanks this.
  5. qmckay
    4
    You suspected right
  6. qmckay
    4
    You know what the problem is ?
  7. Heavyd
    Heavyd Road Train Member
    7,828
    6,277
    Feb 4, 2009
    Either you have a bad boost control solenoid, or wiring to it. If you unplug it and insert a paperclip into the harness connector to short the pins, the code should change to 1257 for a shorted circuit to show the wiring is ok. Then you know the valve is bad.
    AModelCat Thanks this.
  8. qmckay
    4
    If it is a bad boost control solenoid , how much do you think it will cost to have it fixed ? Just trying to get an idea because it sounds like you know what you are talking about
  9. Heavyd
    7,828
    6,277
    Feb 4, 2009
    The valve itself is easy and quick to change. I don't know the price of it.
    qmckay Thanks this.
