International ESC Breakout box
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by eng.moh.4u, May 1, 2017.
  1. eng.moh.4u
    eng.moh.4u Bobtail Member
    40
    4
    Jan 13, 2017
    My international 7500 Truck have AC fault code and when check the diagnostic manual I found below:
    install the breakout box at ESC connector (1600), and check the status of the control head diagnostic line at connector (1600), terminal 8.
    1. If the signal on the diagnostic line is an alternating voltage of 1 pulse per second (0.5 sec high/0.5 sec low), replace the HVAC control head. (Control head is indicating a multiple fault when none exists.)
      low < 2 Vdc
      high > 7 Vdc
    2. If the signal on the diagnostic line is not an alternating voltage of 1 pulse per second, replace the ESC.
    Can I make the test without this tool?
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Yes. Just be careful not to damage the pins. They insist on breakout boxes because there are some gorillas out there that don't know what they are doing and cause more harm than good.
    tony97905 Thanks this.
