International LT engine brake
Discussion in 'International Forum' started by Voyager1968, Sep 26, 2022.
  1. Voyager1968
    Voyager1968 Road Train Member
    2,378
    2,907
    Sep 11, 2008
    I just started with a company that runs mostly LT Internationals, and I have a question about the engine brake. Every truck I've ever driven, when you have the engine brakes turned on, will engage the engine brake when you lift your foot off the accelerator. The LT I'm driving now will coast without the engine brake when you lift your foot until you apply the foot brake, then it will engage. Is there any way to change this parameter or is it just something I will have to learn to live with?
    kemosabi49 Thanks this.
  3. N00bLaLoosh
    N00bLaLoosh Road Train Member
    1,027
    8,026
    May 13, 2021
    Novi, MI
    I had the same problem. It was an AMT and the company had me locked out of manual gear selection. The solution was to whine a lot until they let me select gears. I may have mentioned 'safety' a few times.
  4. tarmadilo
    tarmadilo Road Train Member
    1,733
    4,775
    Dec 12, 2018
    My LT is a 10 speed manual, engine brake works normally.
    N00bLaLoosh Thanks this.
  5. InternationalExpert
    InternationalExpert Bobtail Member
    10
    5
    Mar 1, 2022
    International has an optional parameter where the jake is latched to the brake pedal. You could ask your company if they would be willing to change it. other than that there is no work around.
  6. Voyager1968
    2,378
    2,907
    Sep 11, 2008
    That's what I was afraid of. Thanks.
