Interstate Load?
Discussion in 'Questions From New Drivers' started by d007, Jul 24, 2011.
  1. d007
    d007 Bobtail Member
    22
    10
    Jun 16, 2011
    Our company employs a lot of people under 21 and we drive trucks that are 20,000 to 25,999 GVWR. If our plant is a couple hundred feet over the Michigan line and all of our customers are in Ohio, then is everyone there in violation of the interstate load requirement? Because were hauling product from Michigan into Ohio and not 21.
    123456 Thanks this.
  3. misterG
    misterG Road Train Member
    2,884
    8,981
    Jan 21, 2009
    ask my dispatcher
    I wouldn't think so. Being that your trucks are not rated for CDL's.
    That is a great question though, and one that should be asked of the local DOT.
    Here, you will get many, many responses, a few of them might even be right. Most of them won't be however.
  4. d007
    d007 Bobtail Member
    22
    10
    Jun 16, 2011
    Its an interesting situation. I have a CDL but K restriction. Sometimes they put me in a 29,000 GVWR truck. Since we're so close I get rides over the line to be safe, but would any cop stop us for going one driveway over the border? . Door shield says Ohio location, and we have a PUCO number if that helps. Thanks for your help!
  5. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    You are exempt from the CDL program 26,000 lbs and under. You need a Class B license to drive the 29,000 GVWR and 21 years old to cross state lines with a CDL. If a company is engaged in commercial enterprise and they use vehicles of 10,001 lbs or more, the only requirement is it's drivers must have a DOT medical card.
    I'm sure the company is pulling a quickie with the 29,000 GVWR truck as you said it has an Ohio address and being a couple hundred feet in MI. The odds of getting pulled over in MI are nil.
    But you are correct, they are in violation with that 29,000 lb truck if they let someone with less than 21 old age and a class B drive it across the line. I would bring it to your bosses attention. They can't force you to drive that truck either.
    My understanding is you have a MI license. All it takes is one accident or pull over in OH and you will have some answering to do. But you could always move to OH within 30 days change your license and they couldn't do anything.
    So you see it's one of them things you could get in trouble, but then you could get out of it. The company would of been better off if they didn't buy that truck.
    Pour some sugar in the tank, lol. :)
  6. d007
    d007 Bobtail Member
    22
    10
    Jun 16, 2011
    I have an Ohio CDL so I'm golden there.
