INVERTER ISSUES! UGH! PLEASE HELP!
Discussion in 'Ask An Owner Operator' started by Batman13, Nov 27, 2021.
  1. Batman13
    Batman13 Light Load Member
    110
    45
    May 20, 2020
    ANY INFO WILL HELP...PLEASE NO SNIDE OR SMART ### REMARKS!
    Ok so the inverter I had before was 3000watt..it was going draining my batterys and wouldnt stop beeping..checked the batteries and there was blue crust #### on the terminals..cleaned it out and replaced the batteries..bought a need inverter its 2000watt..it was doing fine..but now as soon as I turn it on...it beeps without even having anything plugged in..any info why its acting up?
  3. JonJon78
    JonJon78 Road Train Member
    7,242
    43,050
    Jul 1, 2018
    Do you leave the truck off the entire time you're using the inverter?
    To prevent corrosion on the terminals/cables use battery terminal grease
  4. Batman13
    110
    45
    May 20, 2020
    No the truck stays on for a while the its off for a few hrs...
    Rideandrepair and JonJon78 Thank this.
  5. AModelCat
    164,921
    Did you read the owner's manual for the inverter? Unfortunately that beeping could mean anything.
  6. Batman13
    110
    45
    May 20, 2020
    Yea checking it now..Im pretty sure its the wires..
    Rideandrepair Thanks this.
  7. Qbf594
    Qbf594 Road Train Member
    1,642
    8,715
    Aug 15, 2019
    Southern Canadian annex, NY
    Without knowing the specs on your inverter it's not possible to precisely diagnose the problem. If you leave the inverter on 24-7 it's tapping your battery bank 24-7. Which is unnecessary and unadvisable. If the inverter is reading the voltage being low while no load on the 120ac it's likely your battery bank is weak. It might be just 1 crap battery. Even 1 crap cell in 1 battery. But the weakest link is the best your 12v supply will do. Swapping out 1 or 2 batteries will reconfigure the bank but now your New batteries are limited by the crappiest of the Old batteries remaining.
    Your available 12v system is probably at around 14.4v while being charged via alternator. At 12v when truck is off. A few minutes of heavy loading on the inverter and it's down to 11 or 10v and every minute in that state is killing HOURS of life off the cells in the battery. (Actually it's # of charging cycles and depth of charging but nevermind all that lol...) It's damage is irreversible.
    Bite the bullet, buy a whole new set of Dual Purpose (deep cycle and CCA) batteries for the truck. Turn off the 120ac side All Day Every Day unless you're using it and when you do use it run the truck.
    Or put a harbor freight 2000w generator on the catwalk.
  8. Qbf594
    1,642
    8,715
    Aug 15, 2019
    What size wires are they.
    How long are the wires from the batteries to the inverter.
    Are the red and black wires at opposite corners of the battery lineup.
    feldsforever and Rideandrepair Thank this.
  9. Spyro2112
    Spyro2112 Medium Load Member
    624
    434
    Mar 17, 2018
  10. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    Start with 4 new batteries. They do t need to be deep cycle, just get the big ones (950-1000CCA). Make sure your wires are at least 0 gauge and as short as is feasible.
    I can leave my truck off all night and still make 12c of coffee in the morning w/o cranking up the truck. That's with the apartment size refrigerator running all night.
  11. shooter19802003
    5,654
    42,113
    Feb 8, 2010
    Gonna say 2 things. It's drawing too much current. So the wires are too small. Also batteries are prolly bad. Batteries in trucks don't last long at all. If you run an Inverter, you get about a year out of your batteries. Load test them and find out.
