Inverter
Discussion in 'Experienced Truckers' Advice' started by Trucker327, Jun 23, 2019.
  1. TROOPER to TRUCKER
    TROOPER to TRUCKER Anything Is Possible
    7,679
    12,757
    Dec 15, 2014
    Charlotte, NC
    How’s the maintenance etc gonna go?
    spyder7723 Thanks this.
  3. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    I've already answered this...lol. Well, maybe not the "why" part, which is fuse before the inverter so the thing doesn't catch fire. I've installed my own after watching how it's done and asking questions. Have even been complimented on my installations. Have had the breaker trip on a couple occasions, usually while working with power tools.
  4. Ridgeline
    22,760
    124,279
    Ok I missed part of your post, but you are right with an exception, you don't want to cut the cable a foot from the battery but want to have the fuse or breaker right at the battery. You want to eliminate any part that has a chance of turning the cable into a way to start a fire. As trivial as that sounds, there is a chance unless it is stopped at the source.
  5. spyder7723
    spyder7723 Road Train Member
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    With some very expensive lessons.
  6. rabbiporkchop
    9,678
    6,548
    Feb 9, 2012
    Wapwallopen, Pa
    I'd install a breaker under the cab near the batteries.
    FlaSwampRat Thanks this.
  7. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Have the dealer of your truck make install it professionally.
    This is NOT to be fooled with, you can burn down that truck doing it wrong.
  8. x1Heavy
    34,016
    42,144
    Mar 5, 2016
    That's not big enough. when 4 batteries are kicking a sleepy cat over... the amperage alone will burn though it.
    rabbiporkchop Thanks this.
  9. Rideandrepair
    17,578
    56,942
    Aug 8, 2015
    I’ve done some research, and will install my own.Seems to be a lot of conflicting info, for such a simple thing. For that reason, I’ll do if myself. I give the OP credit, willing to ask questions and learn. Harbor Freight sells cable sets and advance auto sells 300 amp fuse for battery.
    Trucker327 and JonJon78 Thank this.
  10. rabbiporkchop
    9,678
    6,548
    Feb 9, 2012
    Wapwallopen, Pa
    What does the starter amperage draw have to do with inverter amperage draw?
    If the breaker is wired as a protection circuit for the inverter, I fail to see how it will get tripped when the starter is cranking.
    FlaSwampRat and Rideandrepair Thank this.
  11. JonJon78
    JonJon78 Road Train Member
    7,246
    43,304
    Jul 1, 2018
    Not sure why everyone here is making this out to be such a big deal... LOL. I think you'll do just fine.
    I installed mine with cables purchased from the link that I posted above a couple years ago and my truck hasn't burnt down yet... Its really not that difficult.
