Inverter
Discussion in 'Experienced Truckers' Advice' started by Trucker327, Jun 23, 2019.
  1. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    I think direct current is nasty. Picked up one of thoes 12v coffee makers a while back and the plug got so hot it melted, the wires near the plug melted, and the ciggaret lighter socket melted. Even with a fused receptacle it messed things up. ouch.
    Rideandrepair and rabbiporkchop Thank this.
  3. spyder7723
    spyder7723 Road Train Member
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    Because a bunch of morons have crossed the cables or ran them in a way the insulation rubbed through causing a fire. So now everyone thinks you need to be a certified electrician to run a couple cables. And you must install a breaker big enough to handle a factory running 440 volt.
    Stupid in my opinion. An inverter that uses 4 gauge cables is supposedly so dangerous, yet your starter that uses cables 4 times as big is wired straight with no breaker.
  4. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    The breaker can only take so much. It's a item we never dealt with when we ran a inverter in our rig. On or off was the two things possible with it.
  5. stuckinthemud
    stuckinthemud Medium Load Member
    620
    3,063
    Oct 20, 2013
    starter cables apparently do not have fusible links for protection from short circuit. Sorry for an extremely inaccurate post
    Reason for edit: trying to correct error
    Rideandrepair Thanks this.
  6. Ridgeline
    22,772
    124,492
  7. spyder7723
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    Thats between the ignition switch and starter. The cable going from battery to starter is always hot and has no breaker or fusible links.
  8. rabbiporkchop
    9,678
    6,548
    Feb 9, 2012
    Wapwallopen, Pa
    But when you're starting the truck none of the amperage is going through the circuit breaker since it's a separate circuit.
  9. stuckinthemud
    620
    3,063
    Oct 20, 2013
    I am not a mechanic or electrician , the article I relied on is here
    Blowing the Lid Off Car Fuses and Fusible Links
    Fusible links can be found in a variety of places in cars and truck, but they are commonly used in high-amperage applications like starter motors,
    And I could easily be wrong
  10. spyder7723
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    You are right you are not a mechanic. You are confusing the little baby wire going to the bendix from the ignition switch with the main cables that run straight from the batteries.
    I've changed starters on everything from a car to a truck to a bulldozer, 12v and 24v. The main cables which are an inch thick are straight connections, no fuse, no breaker, nothing.
    HoneyBadger67 Thanks this.
  11. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
