Inverter
Discussion in 'Experienced Truckers' Advice' started by Trucker327, Jun 23, 2019.
  1. Ridgeline
    22,772
    124,483
    You can't use 4 gauge wire, the draw on the batteries is about 260 amps, the length will be about ten feet on how you route it and you will need to use grommets and secure the cable. 0000 is the best, you can get away with 000 if you need to but it has to do with the voltage drop from the batteries to the inverter.
    FlaSwampRat Thanks this.
  3. Tb0n3
    Tb0n3 Road Train Member
    4,744
    9,663
    Oct 5, 2012
    Earth
    2/0 or 4/0 copper cable, and protect all the holes with rubber grommets.
  4. spyder7723
    spyder7723 Road Train Member
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    All those install kits most shops use are 4 or 2 gauge cable.
    rabbiporkchop Thanks this.
  5. otterinthewater
    5,598
    29,364
    May 10, 2018
    Santa Barbara, Ca
    I had friend that had a competition car audio shop that went to IASCA world finals a bunch of times and had van that did some insane SPL.
    The do it yourselfer’s were the bane of his existence. Fuse it within 18”. Split loom it, they make water tight pieces for going through sheet metal to prevent abrasions, and most likely any do it yourselfer will get it to work, but from what I saw they were one misstep away from a fire.
    Do a risk/reward sheet. If your tractor is your living I would make sure it was done correctly. If you’re not sure find someone to install it, or find a shop that will check it out after you install for a few bucks.
    FlaSwampRat, stuckinthemud and Tb0n3 Thank this.
  6. rabbiporkchop
    9,678
    6,548
    Feb 9, 2012
    Wapwallopen, Pa
  7. Ridgeline
    22,772
    124,483
    Yeah they do and that's why I don't ever use them.
  8. 88 series vet
    88 series vet Light Load Member
    53
    52
    Feb 28, 2015
    rock hill sc
    The replies here are hilarious to say the least. As someone who was an automotive electrician, if you have ever installed a system in your car. Its the same principle. Good hot, good ground and a protected circuit. So many on here act like you need an electrical engineering degree
  9. spyder7723
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    And yet you tell everyone it needs to be done by a shop..... who will use one of those cheap kits.
    adayrider and Trucker327 Thank this.
  10. spyder7723
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    Thank you. Some one with some common sense.
  11. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    You can stick weld with a battery and jumper cables. A truck has what 3-4-6 batteries? If something goes wrong it's going to "weld" a long time and likely burn something down. Considering the cost of a truck and subsequent downtime I don't think it's unreasonable to advise having someone else do the install when the person with the question is in doubt.
