Inverter
Discussion in 'Experienced Truckers' Advice' started by Trucker327, Jun 23, 2019.
  1. otterinthewater
    5,614
    29,440
    May 10, 2018
    Santa Barbara, Ca
    Good idea. Tell a total laymen good hot good ground protected circuit.
    How do they do that? What’s the reasoning? Why is it important to fuse within 18” of the battery. I know the answers. Do they?
    Your experience makes it seem simple. You have no idea on the technical acumen of the people you’re talking to. Most people will over estimate their abilities and underestimate the consequences. You are feeding that.
  3. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    This is all in reply to a person who asked how to remove lights and a radio. We already know their 'technical acumen'.... Now it's just a debate among those of us with more ability as to just how simple the job really is.
  4. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    I'm using 3/0. It's the largest size that will fit into the breaker.
  5. Trucker327
    Trucker327 Light Load Member
    176
    20
    Dec 24, 2017
    Asking questions is how you learn..for all of you who dont know lol! Im not an op who'll just hand someone a #### load of cash and say do this and that...when it isnt hard to do research..get info..and learn..id rather learn on my own for future situations..and save cash! Ive installed a touch screen radio..an amp..and a base canon..now working on an inverter!!
  6. Trucker327
    176
    20
    Dec 24, 2017
    If people would read correctly...the question was not about the radio..but the deck...how to remove it without having to damage or cut it up as a last resort..and the lights...well whoever last did them..really did a number on em...thank you..dont be so quick to jump the gun...
  7. Trucker327
    176
    20
    Dec 24, 2017
    If you would read correctly...the question was not about the radio..but the deck...how to remove it without having to damage or cut it up as a last resort..next time you should read correctly before replying..and the lights...well whoever them..really did a numbe on em..thank you..
  8. Moosetek13
    Moosetek13 Road Train Member
    15,066
    19,177
    Nov 1, 2010
    Burnsville, MN
    So the OP finally decides to grace us with a response after several days, mostly in response to the radio/deck thing.
    I have not searched for all the OP's threads, so I do not know of that one. Don't really care.
    But I was wondering, Trucker327, if you learned anything useful with your original question in this thread?
    Because I have seen nothing of any real help here. I can't give it to you either.
    My first 'real' inverter was factory installed.
    It resides under my bunk on the drivers side in the side compartment.
    There are 120V outlets on both the right and left sides of the sleeper.
    No aftermarket installation will do the same without considerable cost and effort, on anyone's part.
    Doing it yourself you have to consider where you will actually mount the inverter, then figure a way to get those thick power cables to that location from the battery safely.
    I've seen a lot about the cable size or the overload protection, but what about what is needed to protect the cable going through the hole that was drilled?
    Or about the tools needed to get the job done. Some of those clearances might require something special just to drill the holes, so keep that in mind.
    Personally, I would not try to do it myself as there are too many things I might miss - no matter how many videos I watched.
  9. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    There was a reply in here about step bits and grommets.
    rabbiporkchop and Moosetek13 Thank this.
  10. rabbiporkchop
    9,680
    6,548
    Feb 9, 2012
    Wapwallopen, Pa
    Those are the first things someone would need to have before they start the job.
    FlaSwampRat Thanks this.
  11. JonJon78
    JonJon78 Road Train Member
    7,248
    43,444
    Jul 1, 2018
    Why respond then if you have no clue? :eek:
