1. driverdriver
    driverdriver Road Train Member
    4,254
    5,284
    May 30, 2011
    Is your truck running while it's on?
    On mine the display is in reference to the state of charge on my batteries.
  3. jimjam38
    jimjam38 Medium Load Member
    458
    73
    Nov 6, 2011
    chickasha, oklahoma
    I am idling the truck yes.
    I did find markings on pot. That little thing pulls 700w. Who would have thought.
    driverdriver Thanks this.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    If the coffee maker has a bunch of electronics in it, it may require the use of a pure sine wave inverter to operate properly. A simple on/off type coffee maker should work fine.
    If the appliance draws 750 watts while brewing, the inverter will pull about 75 amps from the batteries. If you had it set to fire up with the truck off, it would have caused a low voltage condition and shut itself off. When you fire up the truck it will work fine. Unless it needs the pure sine wave type inverter.
  5. Ridgeline
    22,755
    124,122
    There are a couple things here.
    First off this is an inductive load, a little different than normal loads.
    Second the five cup I have sitting here (mainstays) is 1200 watts, not 750.
    Third there is overhead for every inverter so if you are using 1200 watts, may a couple hundred is being lost in heat and running the thing. The fan will run for a bit to lower the temps on the switching transistors.
    Fourth that one is a chinese made modified sinewave inverter which more often than not isn't too great for coffee makers.
    Fifth and finally, I hope you have it wired in right and it is fused.
    rabbiporkchop and uncleal13 Thank this.
  6. jimjam38
    458
    73
    Nov 6, 2011
    chickasha, oklahoma
    It was wired in by the tech they use to install the eld devices. He showed me where he hooked into the battery and installed a circuit breaker so know where tocut power of I have to.
  7. driverdriver
    4,254
    5,284
    May 30, 2011
    Yeah the first time i was going to get an inverter and had to figure out how big I was very surprised to find out how many watts these little pots use.
  8. driverdriver
    4,254
    5,284
    May 30, 2011
    I have The same pot as him , it says right on the bottom 700w manstays ( walmart) 5cup. Been using them for bout 5 years.
    Before that Mr. Coffee those are 650w.
    Up until last February I've ran them on Chinese modified sine with no problem.
    The Mr. Coffee I used to run that off a 1000w.
  9. jimjam38
    458
    73
    Nov 6, 2011
    chickasha, oklahoma
    The wife was the one who picked it out. After she rode on truck and I used the one cup maker I picked up at a flying hook, she said she wasn't going to wait 30 minutes for one cup of coffee lol. This being a different model inverter, I was not expecting it to do that. As long as it works, I am ok with it. There are times when I am stuck away from a loves or pilot to use points for a refill. And that one cup maker ended up in the trash when the #### plug melted on it.
  10. joesmoothdog
    joesmoothdog Heavy Load Member
    737
    1,144
    Aug 5, 2013
    OTR
    I heat water in the mike and use a french press. Way better cup of coffee. Takes about 10 minutes from start to finish. About the same time as a pretrip while I'm getting dressed and circling the truck. 16 0z water at 6 mins in the 50$ mike. 4 scoops of MH colombian in the carafe. Zoom baby!!!:blob6:
  11. Olympian
    Olympian Medium Load Member
    334
    169
    Jun 21, 2013
    One of the companies I worked for had those 1500W cobras in their trucks, but they sucked. As I had to start the engine every time I had to use my microwave. Otherwise, I couldn't use it.
    The 1800W cobras work far better, relative to the 1500W models, at least for me.
