Inverters for game system
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by BazookaJoe, Dec 8, 2018.
  1. BazookaJoe
    BazookaJoe Light Load Member
    281
    228
    Mar 7, 2018
    Was thinking of hooking up a Xbox.
    Figured I would definitely need an inverter to do so.
    Question is how big etc. how do I go about hooking up a Xbox.
    I have a 2019 T680 no apu.
    Any help from someone that’s done it is much appreciated.
  3. Brandt
    Brandt Road Train Member
    4,625
    6,359
    Sep 17, 2012
    You probably want a Pure Sine Wave inverter
    BazookaJoe Thanks this.
  4. Gdog66223
    Gdog66223 Road Train Member
    1,871
    2,569
    Dec 30, 2017
    Coal Town
    I got a power drive 2000 watt inverter and I run a ps4, 32 in TV, dorm fridge, microwave and it does just fine...
  5. BazookaJoe
    281
    228
    Mar 7, 2018
    Sorry been busy. Appreciate the response I’ll check that out
  6. BazookaJoe
    281
    228
    Mar 7, 2018
    Thank you I’ll look into it
  7. Tb0n3
    Tb0n3 Road Train Member
    4,738
    9,652
    Oct 5, 2012
    Earth
    Be very careful to install it properly. You'll need large gauge wires from the batteries, preferably with grommets to keep it from fretting on holes, and a fuse to protect the truck from burning down. When I say large gauge I mean 2/0 or 4/0.
    Mattflat362 Thanks this.
  8. Gdog66223
    1,871
    2,569
    Dec 30, 2017
    Coal Town
    I went to Lowes and had them cut 6 foot of 4/0 wire with the connectors and I had used a big pair of crimps to crimp them down... Works fine for me.. You can buy the 6 foot of 2/0 wire already made at Harbor Freight for like $30...
  9. Ridgeline
    22,727
    123,476
    Fuse it at the battery, not at the inverter.
    It will draw about 160 amps with 2000 watts, so you will need a pretty large fuse.
  10. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    You will want a larger pure sine wave inverter. One that feeds relatively really clean power to computers.
    You would want such a inverter overengineered and installed by your truck dealer. So it will not burn, fail or cause trouble when you are away. (Massa'gone away Gremlins (1980) movie come out to play. =)
