inveter
Discussion in 'Millis' started by bryanrutledge, Dec 15, 2013.
  1. bryanrutledge
    bryanrutledge Light Load Member
    205
    35
    Sep 18, 2012
    snellville ga
    I need a new inverter, the one I got from millis was a used one and quit working. millis wants to much for a new one. where can I get one that is millis approved? does anyone know a web site I can go toand get one? thanks
  3. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    210
    Jan 31, 2012
    Green Bay Wi
    well what ones do millis approve
    a pure sinewave inverter is more expensive then the cheap TS variety
  4. missjhawk
    missjhawk Medium Load Member
    571
    324
    Jul 24, 2013
    nutbush
  5. cabwrecker
    cabwrecker The clutch wrecker
    1,626
    1,425
    Mar 23, 2012
    Early on in my time with FFE I picked up a good number of electronics, and even a few appliances, that were fairly high wattage's. FFE's policy regarding inverters were "It had better ###### well be professionally installed or it's the brakes for you, kids."
    Well, I personally never bought that particular line of bull manure, expecting a driver to live in a truck, in the modern world, with all the electronics and appliance amenities available to us; is ridiculous.
    Picked up one of these at a wally-world in Beardstown, IL.
    Also grabbed a line crimper with the necessary attachments and about 50ft of either 10/8 gauge insulated copper, grabbed a few rubber grommets plus zip ties.
    Bolted the inverter to the far side of the divider under my bunk, crimped the eye holes on the wire and installed them on the inverter then ran them through a small hole under the bunk about 4 feet from the battery box. Place the rubber grommets in the hole I ran the wire through and re-threaded them; finished the eye hole crimps on the end and installed them on the batter.
    Put some black conduit around the wires and zip tied them to the frame. Left a few feet of leeway off the frame to the entrance to the cab so the wires wouldn't rip apart.
    Cost me all of $160, and took 20 mins tops to install. Voila- I had 1,500 watts of AC in the truck. (No one ever found out, either.)
  6. db2681
    db2681 Heavy Load Member
    883
    702
    Jun 13, 2011
    Dayton,OH
    amazon is your best bet. The power drive, whistler both meet millis specs, you just pick the wattage.
    bryanrutledge Thanks this.
  7. Myoneload
    Myoneload Light Load Member
    218
    45
    Jan 22, 2013
    around here
    I got a used one 1800 watt in great shape has all the cables to take 200.00 for it.
  8. TheyCallMeTaterSalad
    TheyCallMeTaterSalad Light Load Member
    57
    22
    Jul 23, 2013
    New York State
    The power drive one does meet specs? i was looking at the 2000 w one but figured it would be "Too high". who do you ask about this? I know they have to install it at the shop. they wont let us do it
  9. db2681
    883
    702
    Jun 13, 2011
    Dayton,OH
    any of the shops or qcomm brf shop. When I was there anything below 2400w was ok, according to the shop.
