Invisible air leak
Discussion in 'Trucks [ Eighteen Wheelers ]' started by chopov78, Apr 1, 2016.
  1. chopov78
    chopov78 Light Load Member
    122
    9
    Feb 27, 2010
    illinois
    Need help with air leak.
    I have Volvo 2007yr wit hyundai trailer 2004.Right now trying to find air leak from somewere but can not hear nothing,checked the air lines and air bags,everything looks fine.
    So,when stoped and engine shut 990 of the time the air dissapears in 5 to 10 minutes.
    Nobody can find it,and can not pass tha annual dot inspection.Any idea?Thanks!
  3. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    Is the leak in the trailer or the tractor?
  4. Jerry12
    Jerry12 Heavy Load Member
    723
    282
    Sep 9, 2014
    check the air lines going into the air regulator filter. (while ur there, clean out the metal filter)
  5. chopov78
    122
    9
    Feb 27, 2010
    illinois
    can not hear it
  6. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    I find it very hard to believe that you lose all you air in 5-10 min and no one can hear anything. You should be able to find a leak that bad with a pin wheel, or when you hat blows off, you're close.
  7. chopov78
    122
    9
    Feb 27, 2010
    illinois
    do you mean air dryer?
  8. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    Let me rephrase the question....
    Is the trailer getting air but not holding it? or Is the trailer not getting any air at all?
  9. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    That is why I'm asking if the trailer is getting any air at all.
  10. Jerry12
    723
    282
    Sep 9, 2014
    No. Auto shift tranny will have one to regulate the amount of air pressure going into the transmission. There will be another air regulator before hitting the brake chambers.
    otherhalftw Thanks this.
  11. chopov78
    122
    9
    Feb 27, 2010
    illinois
    bouth getting air and not holding it.
