Is DPF Servicing necessary at a truck stop?
Discussion in 'Truck Stops' started by 7th, Aug 20, 2017.
  1. 7th
    7th Bobtail Member
    8
    Oct 20, 2016
    A couple of questions:
    Would it be beneficial to have a safe area where a driver can perform a DPF Manual Regen at a truck stop, at any time they please?
    Is it a good idea to have equipment that can start Force Regen on any truck at a truck stop, just like they have at a dealership?
    This is for cases where the driver wants to perform a Regen prior to a trip, or has already passed the moment where Manual Regen is possible and the engine is in derate mode. There is no need to waste time finding a dealership or an equipped truck shop. This can be comparable to a lube service - if you'd like to perform a Regen, stop at any truck stop, start Force Regen and go.
  3. Dave_in_AZ
    425,388
    I do a Rolling regen every so often. Run it at about 1600 rpm in 9th gear, that's about 55 mph, for half an hour, that way don't have to do regens.
  4. BigBob410
    BigBob410 Road Train Member
    5,665
    74,101
    Feb 2, 2016
    Beirut on the Bay, MD.
    What is this Regen you speak of?? Is this some new fangled technical term?? Please advise..over...
    Grubby and Cottonmouth85 Thank this.
  5. Brandt
    Brandt Road Train Member
    4,625
    6,359
    Sep 17, 2012
    Why would anybody want to do a regeneration when it not even needed. First the computer won't let do one. Second the truck will regenerate going down the road. Unless you got old and one of the first generation emissions truck. Those thing are a mess, no need to do a forced regeneration only f the computer says you need one
  6. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Those who idle during every break are the ones having parked regen needs and problems. Then factor in the fact many of these systems aren't properly maintained
    dngrous_dime Thanks this.
  7. Brandt
    4,625
    6,359
    Sep 17, 2012
    I have a 2017 Freightliner and it has the old Detroit Optimized idle system. It back on 2017 truck anyway. It will do parked regenerations automatically at 1300 RPMs and only takes 20 minutes.
    Instead of have APU the computer starts and stop the engine for a/c or heat or charging batteries or maintain engine oil temp. After about 7-8 hours of parked idle time it will regenerate automatically.
  8. MACK E-6
    50,056
    238,610
    It's part of a feature designed to make EVERYBODY'S life better.....:rolleyes:
    ....Except the driver, that is.
    BigBob410 Thanks this.
  9. BigBob410
    5,665
    74,101
    Feb 2, 2016
    Why in the world would any aspect of Truckin' have the driver in mind?? pffftt!! We just sit on our butts all day anyway!!! And before anyone starts yelling at me..it was sarcasm!
    ^^^^^^*****Note sarcasm****^^^^^^
    gentleroger and MACK E-6 Thank this.
  10. MACK E-6
    50,056
    238,610
    Whoever wants to tell me that should've volunteered for today's liftgate unload of 22K lbs of car wash soap.
  11. BigBob410
    5,665
    74,101
    Feb 2, 2016
    Heck that makes my back hurt just reading it!!
    MACK E-6 Thanks this.
