Is helping bad drivers through CDL tests to do with turnover?
Discussion in 'Questions From New Drivers' started by blindsidebacker4life, Dec 15, 2018.
  1. blindsidebacker4life
    blindsidebacker4life Light Load Member
    61
    34
    Dec 15, 2018
    I recently graduated a decent trucking school... We had no automatics and loaded trailers and did hundreds of hours of hard-button-hook-turn-city and interstate driving and backing and very detailed PTI that was more than we needed for the test. I specifically wanted this school do to all the different engines and transmissions and loaded trailers.
    I was basically one of the top students out of dozens of students from the start(we had some people who tried and could shift and back and drive decent), but that didn't seem to matter.. Months later when we went to test, all the people from our class who couldn't even do PTI or backing and basically slept or didn't even show up were just walked through all the tests and passed.. They took out a lot of cones and went on curbs and couldn't shift despite all the help,,,, and passed...
    Also, they gave answers to all class work and just passed everyone on the map and final class tests..
    It's worth mentioning this is considered by companies and other schools as one of the top schools, and is state-funded. It's about the only school I found with loaded trailers and standard transmissions..
    Additionally, after a lot of digging and research it seems if you can pass a drug test you're hired at least at most non-union or LTL or tanker companies(unless you know someone of course and get referred in..).. It's all low pay-per-mile and if you're lucky you get a cheap insurance package and 401k.. No fuel bonus, layover or detention, safety bonus etc..
    With these companies they have odd hiring practices too.. With some out-of-school or coming-to-school drivers they will immedetly hire anyone who can pass a drug and recent-felony test. Sometimes though those same companies will do a rigorous checking on employment history; I'm still not sure how they decide on this, but I have seen many clear cases of it happening where they just herd in crowds and then start caring where and when the next flock worked..
    I'm interested in some knowledge on this. Especially with how even reputably-bad companies fluctuate their hiring standards, and is it directly the result of turnover and trying to undercut independents and seasoned drivers?
    Rideandrepair Thanks this.
  3. Chinatown
    Chinatown Road Train Member
    78,806
    189,600
    Aug 28, 2011
    Henderson, NV & Orient
    The real learning starts after graduation from cdl school. That's why companies have a training period for new cdl graduates.
    Did you find a decent job?
    As for hiring criteria, each company has their own criteria. There's jobs available for anyone with a cdl; felons, bad MVR, sex offenders, ex-cons, etc. Some companies decide to hire them and some don't.
    CJ701 Thanks this.
  4. blindsidebacker4life
    61
    34
    Dec 15, 2018
    Yeah I got on at a decent company, but what I've seen gives the impression a CDL and some skill working on the trucks and driving one is quickly losing value to the people who can afford all the costs of being an authority or carrier or whatever...
    I'm pretty sure they predict A.I. trucks hundreds of years too early or something and are just ignoring CSA stats as a temporary inconvenience..
  5. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    So they're passing people to get a cdl who can't pass the test? Sounds like something that needs to be reported to FMCSA.
    CJ701, x1Heavy and Texas_hwy_287 Thank this.
  6. Chinatown
    78,806
    189,600
    Aug 28, 2011
    There's fewer people than can even do the work, so the choices for trucking companies are limited.
    Many people in their 20's don't even have a driver's license and have never driven a car or even know how to put gas in it or change a flat tire.
    CJ701 and Texas_hwy_287 Thank this.
  7. blindsidebacker4life
    61
    34
    Dec 15, 2018
    I'm pretty sure I wouldn't be the first to report it. The testers were all shaking their heads and a lot of people seen it. It looked like companies kind of knew too..
    As someone who can actually change a tire or diagnose a compression or DPF problem I wish that were true.. When I said I can work on engines and graduated Wyotech long ago the people at orientation couldn't care less like I was bragging I could break a horse at a Starbucks or something..
    Chinatown and x1Heavy Thank this.
  8. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    And yet somehow it's the HOS that are causing accidents.
    Rideandrepair and ZVar Thank this.
  9. Rooster1291979
    Rooster1291979 Road Train Member
    1,308
    1,751
    Sep 4, 2012
    NOLA
    Its doesn't matter if you're first or last in your school. New companies will treat you the same. As brand new drivers.
    You will go with a trainer and learn much more than you did in school.
    After a year the better companies open up and drivers will be ranked based on CSA, number of jobs, MVR and PSP.
    Moving into the harder specialized fields are the ones that really care about your "skill".
  10. Kshaw0960
    Kshaw0960 Road Train Member
    1,581
    5,025
    Jun 17, 2018
    The good ones become oo and make bank, the bad ones continue to complain how bad trucking is.
    CJ701 Thanks this.
  11. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    First off if I am at a DMV revenuer testing big rig drivers for CDL mashing cones and crossing curbs etc and still passing the bad drivers who failed, (Plural) then there is a problem. Someone is going to have to find me several whistles to start.
    Trucking companies could care less if you were top ranked or bottom doolie in your trucking school. I was valdectorian in my high school but no one in life gives a #### about that. It is essentially a speech that is for show to the public who does not really know anything about the class. Basically a showman performing up there. Nothing more for a few minutes. It means nothing. Particularly my class if anyone tried to argue my grade levels some of which are college level for years. There are three other people in that group are better at certain grades than I will ever be. All I had was 9.3 grade math.
    Driver turn over? 100 wanna drive a truck. 50 will not qualify medically, physically etc. Even life reasons babies, divorce, sick, caregiving etc. Out of that 50 you might have 40 that will get hired onto the first trucking job. (I was fired in three months for denting a hood of another company truck.) so leave it 30 or so after three months. 25 after 9 months.
    One company in Gettysburg PA had 224 drivers when I hired on. I was number 225. 7 months later I was in the 30's Because the other 190 have quit, fired, lost freedom, hurt bad etc. The top 15 were either family or those hard core prime who will still be driving long after we are gone. HOWEVER 3 of those 15 left the company for better pay and a quieter dispatch culure with less threats of firing for not being on time, 3 feet of powder is no excuse. And you are fired. Eventually the entire company burned down figuratively. Poof. All gone. Not so sad. PA might have had a hand in that shutdown. And for many good reasons.
    Companies contribute to the turn over in several ways. FIrst low pay. 0.30 for decades. Are you kidding me? They should be paying around 0.65 or... full salary of gross 2250 weekly per soul in that truck. If it's a husband wife team then it's going to be a flat 4500 weekly to them. If you can get the loads for them to make two trips coast to coast in 6 days like we did with FFE. (They paid me 40's and the wife low 30's Her training pay was .28 but my trainer salary made miles meaningless at 2200 plus gross and 1550 net after deductions and extra witholding. I could focus on just delivering and training. I did not care if it was 20 miles that week or 20,000.
    That usually takes care of any turnover issues. If they salaried us 4500 a week we would never have left FFE and still do those coast to coast turns or Mckesson etc. The revenue is there.
    Anyway.
    The rest of the thinking about turnovers would have to focus on the first 6 months of all new drivers. They are going to rub telephone pules tear tires on curbing, rip out a shaft U joint on the first scales dead pull of trailer tandems for weight and so on. Instead of flat firing these poor people because they never broke stuff like that before, make them share in the cost of the damage. In my time if I tore a 250 dollar tire vs a hydrant Guess what. I am 250 lighter in pay for that week. Where would i like to take the old tire? I learned to take it to a recycling plant across the county and get a few dollars for it. So it worked out well. Plus I would physically be dealing with the 5 spoke bolt system, wheel ring and new tire onto the truck before i took it out. Manually. No air gun or nothing. (Punishment, then truck is taken out 50 miles and back and then air gun is applied for double checking)
    But no companies simply dismiss drivers for what I consider minor preventables and whoops. Now.. there are certain number who are truly stupid (Seriously.. it is actually a impediment to long term trucking) and should be trained for something outside of the industry in life.
