Is it possible to skip shift a 9 speed?
Discussion in 'Questions From New Drivers' started by Nirvana, Sep 24, 2014.
  1. Nirvana
    Nirvana Light Load Member
    205
    53
    Jul 5, 2014
    Gloucester, Virginia
    I going back to work soon they run 9 speeds mostly.
    I have experience skip shifting 10 speeds example if you don't know what I am talking about is starting out in 2nd gear skipping to fourth then 6th gear. Or 3-5-7. can this be done in a 9 speed....
  3. 8thnote
    8thnote Road Train Member
    1,980
    3,687
    Aug 12, 2013
    Chattanooga, TN
    Maybe on the low side, but the gears are spaced really far apart (ratio wise) on the high side. I don't see it happening loaded, unless you're revving it to 2500 rpm
  4. Vintage
    Vintage Light Load Member
    142
    119
    Mar 16, 2013
    Sea to Shining Sea
    when pulling a loaded trailer there is really no need to skip a gear just for the hell of it...i can see skipping a gear because you're starting off on or near a downgrade and as the truck builds momentum you might be forced to skip to the appropriate gear
    BROKENSPROKET and okiedokie Thank this.
  5. Mev
    Mev Road Train Member
    3,109
    1,102
    Jul 29, 2009
    If it's got gears , you can skip them
    gpsman and Lepton1 Thank this.
  6. Big Don
    Big Don "Old Fart"
    17,996
    35,645
    Sep 8, 2007
    Utah's DIXIE!
    Fixed it for you!:biggrin_2559:
    To the OP, the easiest way to find out is to try it. Of course if you break it. . . .:biggrin_2551:
  7. okiedokie
    okiedokie Road Train Member
    14,106
    112,444
    Jun 13, 2011
    PNWET
    In certain situations yes. But mostly no. I hope that cleared everything up.
  8. Edgar2191
    Edgar2191 Light Load Member
    178
    33
    Apr 9, 2013
    this is why i dont have drivers anymore. Why would you even want to skip them wow just wow.
  9. unloader
    unloader Road Train Member
    1,037
    1,156
    Jan 7, 2013
    You could do it empty, but if you were loaded to skip without lugging down would mean you'd have to rev it high... Which of course you can do, but I'm sure your shop might have something to say about it.
    unloader
  10. kenszo47
    kenszo47 Light Load Member
    55
    17
    May 21, 2012
    DELAND,FL
    Skip gears? Whats the rush? Ya can't drive em like a four wheeler. Learn to enjoy (catch all gears) your ride.
  11. Rooster1291979
    Rooster1291979 Road Train Member
    1,308
    1,751
    Sep 4, 2012
    NOLA
    Sure skip gears no problem. Start in 2nd if loaded, skipping low and 1st, start in 3rd if empty skipping low, 1st and 2nd. Skip gears all the live long day!
