Is my amplifier working?
Discussion in 'CB Radio Forum' started by Hot_Shot_Driver, Jul 17, 2018.
  1. Hot_Shot_Driver
    Hot_Shot_Driver Bobtail Member
    I have a Cobra 29 with a Lil Will 36" whip antenna and a Silver Claw 200 amp. When I turn the amp on the static noise gets quite and I can turn the squelch way down. When I turn it off the static noise gets louder and I have to turn the squelch up. Is this how it should be or do I have something wrong?
  3. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    something ain't right...static should stay the same...unless the Amp has a "pre-amp" switch, but if it did, then when the amp is turned on the static would get even louder...Best thing to do is get a SWR/POWER Meter and hook up so you can see if your watts go up when transmitting...
    rabbiporkchop Thanks this.
  4. Hot_Shot_Driver
    With the amp off the SWR meter on the CB goes about half way up, with the amp on it maxes out when the mic is keyed.
  5. shogun
    shogun Road Train Member
    6,075
    72,163
    Jan 23, 2009
    Doing a regen
    Are you switching from calibrate to swr? That’s probably why it’s pegging the needle. You key up, use the swr knob to max the needle to the far right, then switch to the swr button. If you don’t have a direct short it should drop back and show you the actual swr number. 3 to 1 is direct short range.
  6. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Meter on the radio won't tell you if the Amp is working or not...It just shows what the radio itself is doing...You need a in-line SWR/POWER Meter that you hook-up between the Amp and antenna...You would also need a short jumper coax (3' jumper coax is about standard what most people use) to hook it up,
    Something like this...This one is good up to 100w's.
    WORKMAN SWR-3P CB RADIO ANTENNA SWR / TEST METER WITH 3` JUMPER COAX 714833145288 | eBay
  7. cleanrf
    cleanrf Bobtail Member
    11
    Jul 19, 2018
    More than likely the keying transistor in the keying relay circuit. Do you hear a faint "Click" inside the amp when you power it on?
