Is pulling a Fuel Tanker stressful?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by ruckusftlc, Apr 6, 2021.
  1. ruckusftlc
    ruckusftlc Light Load Member
    106
    56
    Nov 30, 2018
    Hi there
    I’m driving since 2 years 95% local 53ft with sleeper. 3-6 stops a day and touching freight. 50k pounds a week. im looking to change to haul petroleum local. They pay well like my job I have now. I’m just wondering. It’s hauling petroleum stressful? Is it hard to learn? Heavy lifting?
    thanks
    bentstrider83 and austinmike Thank this.
  3. Phantom Trucker
    Phantom Trucker Medium Load Member
    381
    683
    Jan 11, 2016
    Calgary, AB
    I didn’t find it stressful at all. There is a fair bit to learn though, but it’s worth it. You work at your own pace. There’s no appointments, you’re on your own to load and unload. It’s great for those who want to do a job with very minimal interaction with others.
    The tradeoff to all of that is having to follow strict loading and unloading procedures. It can be deadly or costly if you make a mistake.
    There’s no real heavy lifting. At the loading point (rack) you’ll swing large loading arms and affix them to your tank for loading. At the receiving end you’ll be handling hoses and tight fills.
  4. ruckusftlc
    106
    56
    Nov 30, 2018
    Thank you for your answer. I’m willing to learn. What about pay? I know it depends on region but if I google it’s says around 70-100k. Does this sound about right?
    austinmike Thanks this.
  5. Phantom Trucker
    381
    683
    Jan 11, 2016
    Calgary, AB
    Yeah. Mind you, I am in Canada and that’s definitely achievable here.
  6. HiramKingWilliams
    HiramKingWilliams Heavy Load Member
    806
    1,291
    May 15, 2019
    State of Jefferson
    Learning the loading/unloading process is stressful. Loading is stressful when you’re on your own at first. Unloading gasoline is a little stressful at first. Diesel is easy. Certain racks are much easier than others.
  7. meechyaboy
    meechyaboy Heavy Load Member
    796
    1,227
    Oct 4, 2018
    Detroit, Michigan
    Stressful no.... Detailed yes very detailed.
    It’s repetition. Load the same way and unload the same way. Once you got a process and backstops it’s easy. The detailed part is loading the correct contract every time and the correct amount. Making sure you actually verify that the load arm is connected to the compartment you want before you autopilot a yes. Making sure you put the correct compartments in the the right tanks at the right stations. It’s not hard just detailed.
    You have to be a proactive enforcer at stations. People are stupid and they will say “oh my bad dude I didn’t see the gas truck” as they smoke a cigarette walking towards it or by the vapor vents. Some people respond to a simple request to put it out... some people you have to yell at...You’ll have to block off entire sections of the parking lot to prevent people from driving in your area.. and you’ll have to wait for some people to take 45 mins to play their lottery and go grocery shopping cause they parked on your fills... unless you got gravy runs like Meijers or krogers sams club or Costco’s...
    Another stressor could be if your paid by the load..
    91B20H8 Thanks this.
  8. mustang190
    mustang190 Road Train Member
    2,892
    6,245
    Jan 18, 2011
    Florida Panhandle
    As others said, it’s very detailed and you do it right the first time, because there may not be a second time. You don’t get in a hurry.
  9. REO6205
    REO6205 Road Train Member
    13,168
    60,500
    Feb 15, 2014
    California.
    Tanker work isn't hard but it's very unforgiving. If you have a spill or a mix you'll have a lot of people wanting answers and you better have them.
    If you have an accident you'll have even more people second guessing every move you made.
    Stay focused, take that extra minute or two to do your job right, and ask lots of questions if you're in doubt about anything.
  10. Cat sdp
    Cat sdp . .
    21,309
    76,241
    Apr 8, 2012
    Orion's Belt
    You spend a lot of time outside, in the weather.........
    Dennixx and meechyaboy Thank this.
