So today im looking at my buddies 05' Detroit in a freightliner. I have an 05' in a twin screw subaru.
His AC compressor had froze and it took out the drive belt. Disabling the alternator, but I noticed his water pump is gear driven, and it is what drives the alternator and AC comp.
On my Cummins two belts ride the water pump. Short belt goes around water pump, AC compressor, alternator, fan, idler and a tensioner. The big belt around the crank, fan, water pump, PS and everything else. In other words its got a redundant fail safe to keep the water pump going even if one belt fails.
Next thing I notice, the Detroit looks a whole lot easier to work on. Water pump looks simple as hell to replace, my Cummins is a bear comparatively. Everything in general on the Detroit looks easier to get at and replace. Granted my Volvo has those stupid inner fender frame work you gotta crawl over to get at anything. But it just looks so much easier to get at.
What about Cat motors? Are all the accessories easier to work on in general. Obviously a long hood motor is going to be easier, thats not really what I am asking.
Guess I am asking in general what motor is the friendliest for an O/O who does much of his own wrenching?
Is the grass greener?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Kansas, Apr 19, 2012.
Well I noticed the cam is easier to replace in a Roit than a Pillar.
From what I've seen, everything on the 5 Detroits Series 60 I've owned is far easier to work on compared to Cats and Cummins.
The hardest part of the water pump is getting the hoses fit with the pipe going to the oil cooler. Compressor, starter,fan hub, etc is all super easy. I watched a buddy change the water pump on a N14 and that looked like way too much work. -
The N14 water pump is not that bad if you know the correct procedure.
I worked on them for a living, and the Detroit is by far the easiest to work on. They give the best fuel mirage, parts are the cheapest, and give the best longevity. -
What a good buddy you are.
Getting ready to swap out the air compressor on a C12. Looks easy enough & can see everything. But a couple of brackets that need to get out of the way first.
As far as the grass is greener thing, look under the hood of a Pro Star. Have never seen so much stuff that has to go away just to even see the motor. -
Look again, Kansas. On an ISX, the water pump is driven by the big belt that also goes around the crank and fan. The small belt driven off the water pump drives the other accessories. If that big belt goes, no water pump. It is NOT gear driven.
To answer your question, water pumps on pre-ACERT Cats aren't too bad, but ACERT's will send you away crying. Detroits are easy, and you already know about the Cummins.
The biggest difference (IMHO) is the part that you're least interested in..not what brand engine, but whether or not it's in a long hood or not. Everything is out in the open, and easy to get to. I've got much respect for you guys who wrench on the aero trucks. I don't think I've got enough skin on my knuckles for it!
Exactly! I've got a 1969 F-100 pickup with a 360 in it. You can climb under the hood and stand on the ground between the engine and radiator while you work on the engine.
I'll take that over the cramped engine compartment in a passenger car (or a new pickup) any day. -
Ya, youre right. I was thinking the short belt grabbed the crank too making it redundant, it does not. I know its not gear driven. My bad.
No argument there, but I was wanting to find out which engine in general is most mechanic friendly. The long hood short hood subject has been beat to death. Hell, I wish I had a long hood truck lol. I slobber every time I see one of those hoods pulled back.
I recently listened to a Kenworth salesman go on and on about the new Paccar engines and how easy they are to work on. Between that and looking at my buds truck it got me wondering. -
I'd say Detroit is at the top, with Cummins and Cat about equal to each other. Be leery of the Paccar motor...I haven't heard too many good things about them.
I wouldn't have ANY brand engine past 2007, for obvious reasons! but if looking at 2007-2004 isx, cat in that order. twin turbos suck on cats, you can get egr delete and ecm for isx and its cheaper to do that to an isx than a cat single turbo conversion. optimally I would have a 2002 6nz any day of the week over anything though.
