3 different trailers this week that I was supposed to hook to and they are way too high to connect to. Sitting here in a yard trying to connect to a 43000 pound trailer, but the pin is sitting 3 inches above the fifth wheel. My truck doesn't have the option to raise the airbags (never knew trucks had that option?) Tried to up the landing gear but landing gear way too stiff for that. This is happening so frequently that I need a solution so I'm not sitting waiting for a mobile guy for 2 hours.
Usually I drop the trailer an inch or so off the ground and deflate the airbags before I drive off.
What is going on with these #### trailers? Is the person dropping them leaving it too high? Pulled a muscle in my back these week because of this ####. Company tries to pin it on me after.
How do you drop a trailer?
Is there a certain way to drop a trailer?
Discussion in 'Questions From New Drivers' started by Canadianhauler21, Jul 14, 2018.
Page 1 of 6
BillStep and rabbiporkchop Thank this.
Crank the gear down until you can just get your toes under it. Dump the air and drive out from under it.
Most drivers will crank it down until it hits the ground. With air ride trailers, it will pivot on the gear when the air is dumped, and the nose will rise up even higher. Spring ride trailers do the same thing when they're dropped empty and then loaded - the rear of the trailer drops under the weight of the load, and the nose and kingpin rises up.
Also, trucks with widebase singles ride lower than trucks with dual tires. So if you have singles, you're going to see a lot of trailers that are high.77fib77 and rabbiporkchop Thank this. -
Carry some 4X4 blocks with you. Dump your air and put your frame under the nose of the trailer. Stack the blocks on your frame, then inflate your air suspension. Now you can crank the gear up with no load and then drop it lower to hook it.
edit: this also works with trailers that are dropped or have sunk so low that your tires hit the underside of the trailer before the 5th wheel picks it up.Last edited: Jul 14, 2018
firemedic2816, silverspur, blairandgretchen and 10 others Thank this. -
Likely either an uneven ground and the trailer got moved from when the driver dropped it, to where the yard dog dropped it.
Then there are 22.5 and 24.5" tires. Different 5th wheel heights.
No, if lowering the trailer, even full, is causing you problems you need to start writing up and refusing to pull the trailers that have bad landing gears.
And if thee is a yard dog around, ask him to pick the trailer up and then roll the legs up a few inches....Last edited: Jul 14, 2018
tinytim, Canadianhauler21, Trucking in Tennessee and 1 other person Thank this. -
When dropping trailers, lower the landing gear until they are a few inches from the ground. Drop your airbags and pull out from the trailer. Sounds like the guy who dropped the trailer never bothered to think about the next driver.
You mean a few centimeters, not inchesTb0n3 and spyder7723 Thank this.
No, inches. High enough that you can slide your toes under the sand foot.
Have fun grabbing one of those in one of these stupid autoshifts.
You get the job done first, THEN write up the bad trailer. Refusing a loaded trailer would cost me money. I don't do things that cost me money.
Page 1 of 6
