is there a way to test a cb antenna
Discussion in 'CB Radio Forum' started by log trucker, Dec 21, 2011.
  1. log trucker
    log trucker Light Load Member
    161
    10
    Dec 19, 2011
    marshfield wi
    Is there any testing I can do on my cb antenna ,ohms test or ?? Ck cable to make sure it was ok but not sure if cb or antenna is bad. Not picking up anything. I think its the antenna,be nice to no for sure.
  3. me only
    me only Medium Load Member
    309
    85
    Nov 9, 2011
    buford ga
    Put it to a swr meter
  4. log trucker
    161
    10
    Dec 19, 2011
    marshfield wi
    What is swr meter. No way I take it with a regular electronic meter??
  5. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    If you don't have a SWR Meter, just go by any CB Shop...Most will test your antenna and coax at no charge.
  6. ArgoGirb
    ArgoGirb Bobtail Member
    Dec 21, 2011
    London Ontario,Canada
    Just like to add many better CB's have SWR meter built in.Not real accurate but in the ballpark!Grounds are very important!If using a mag mount and radio in not mounted to steel run a 12 gauge wire from chassis of radio to something steel in cab,ant will see a ground plane!
    Bighig Thanks this.
  7. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    The SWR meter shows how well your antenna is matched ......
    Here is what one looks like .... it is the black meter sitting on top of a low power transciver .
      File size:
      99.4 KB
      196
      File size:
      102.1 KB
      217
  8. Infrared61ranger
    Infrared61ranger Light Load Member
    149
    36
    Dec 15, 2011
    killeen,tx
    you need to find 1 good quality CB tech that you can count on and get these things checked out by the only CB tech you trust and keep a backup radio that way when your main radio go down you can get it back to your guy, you cant just trust everybody. sometimes working on your equipment is good but in this case go to the pro make sure some1 you trust gives them a vote of confidence
    Trstanich Thanks this.
  9. Trstanich
    Trstanich Light Load Member
    72
    21
    Dec 12, 2011
    Stonyford California
    I have. That same meter don't know how to operate it never could find a manual
  10. WA4GCH
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    EASY .....
    Put it in line between the radio and antenna I use a 3 foor jumper between the meter and the radio.
    Place the switch in forward Push thev mike button and adjust the control until the meter is full scale. Then slide the switch to REV and read it .... it should be below 2:1
    Look at my photos and if you need help just ask ...
    That radio is a small ham radio but the SWR meter does not care ....
