Is This Any Good?
Discussion in 'CB Radio Forum' started by madmoneymike5, Oct 3, 2019.
  1. madmoneymike5
    madmoneymike5 Medium Load Member
    633
    283
    Jan 30, 2010
    Arlington, TX
    Should I buy this for about $18 or something else?
  3. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    It should work fine.
    rabbiporkchop Thanks this.
  4. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    I haven't had good luck with them. They are hit and miss for being anywhere close to accurate.
    If you have a built in SWR meter on the radio it will be slightly better. Or even just a high SWR warning light on the radio? Just tuning the antenna enough to get the warning light to go out is good enough for a while. It doesn't make that much of a difference, well, untill you know you want it to, if that makes sense.
    I have been burned by the cheap meters a few times. Sometimes they work ok.
    18 is cheap enough though.
    Not going to recommend an expensive meter either. It's really not worth the cost for the return. unless you get that bug up your but and want to do it.
    Yeah, if you don't have any SWR indication on the radio then I would but it.
  5. Meteorgray
    Meteorgray Heavy Load Member
    754
    597
    Jan 1, 2016
    I've had good luck with them. Everybody needs something to know how their equipment is working.
  6. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Play with them for 18 bucks. Pass the time. Find out how to make needle go that way alot.
    Then learn why. Maybe as simple as buying a CB shop grouchy a cup o' coffee and a dab out of the silver flask for school time from him telling you why needles do this or that in each meter. (In a way you can understand)
    College is for those who cannot do. But you have a oppertunity. Maybe unlock something inside of you to be the next radio king.
  7. Lowboy456
    Lowboy456 Light Load Member
    295
    143
    Mar 14, 2017
  8. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    They are no better than whats in a stock meter..If those #'s matter to you,save and buy a analyzer and a multi meter...
  9. madmoneymike5
    633
    283
    Jan 30, 2010
    Arlington, TX
    I ended up buying a simple SWR meter. Works for me. What analyzer do you suggest?
  10. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Rig expert aa30 if you can find one and if not the aa35 model...If you plan on in the future to go hogher n lower in freq then have to go higher end models..
    madmoneymike5 Thanks this.
  11. madmoneymike5
    633
    283
    Jan 30, 2010
    Arlington, TX
    Gosh they're pricey! Does Ray's shop in West Memphis, AR have an analyzer?
