is this CB worth fixing? Cobra classic
Discussion in 'CB Radio Forum' started by longbedGTs, Mar 13, 2017.
  1. longbedGTs
    longbedGTs Heavy Load Member
    974
    717
    Texas
    I got a free CB(Cobra 29) from a driver leaving the company, but it's not working. It powers up but there is nothing incoming. Keying the mic just makes a loud "click" from the speaker. Now if the CB weren't fubar already, to top it off I ended up dropping the thing out of the truck from door level and knocked the chrome faceplate loose. This is one of the $119 specials found at any truckstop...so since this was free, do you think I should stop by a CB shop and have it looked at and fixed if less than the price of a new one, or just forget and buy a new one? I haven't ran a CB in 5 years, but want to get one again.
    It was mfg August, 2014 btw.
  3. Bout Z
    Bout Z Light Load Member
    275
    1,149
    Mar 14, 2015
    so. ohio
    Ugh.. prolly better to buy another since it took such a hit. Your money is going to be better spent, buying a new radio..with a warranty..rather than paying someone to fix, what may not be fixable. Jmo
    JReding Thanks this.
  4. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    if you run across Interstate 44 in Missouri you should stop at hoods truck stop and let Jim look at it. He has a reputation for doing $10 repairs.
    His tune is completely worthless but he seems to have a knack for fixing things.
    mike5511 Thanks this.
  5. volvo244t
    volvo244t Road Train Member
    1,775
    1,779
    Jun 24, 2010
    Bettendorf, IA
    I had a bad Astatic D104-M6B mic that I brought to Jim. Had to take the whole thing apart and chase down a bad solder joint, took a little while. Charged me 5 bucks and it worked perfect thereafter.
    rabbiporkchop Thanks this.
  6. mike5511
    mike5511 Road Train Member
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    Russell Clift worked with Jim for about two years. He said Jim was one of the best diagnosticians he'd ever seen. Jim learned his craft from his Father, who had a radio shop in Springfield that did the business band thing, Police, Fire, etc. So, you know he had a good teacher. He tunes with a Bird meter and his ear, or at least he used to. His radios usually sound and perform pretty good though. At least he won't "volt the finals" or do stupid stuff that will cause your radio to die an early death.
  7. volvo244t
    1,775
    1,779
    Jun 24, 2010
    Bettendorf, IA
    When I went in there, he did have a raggedy scope. don't know if it even worked
  8. Ridgeline
    22,724
    123,388
    You don't need a modern scope to work on CBs, sorry guys but I have a 1963 textronix 40 mhz scope that works well enough to fix and tune any radio.
  9. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    Can't see harmonics with a 40 mhz scope although It's a step in the right direction and probably fine for getting things in the ballpark.
  10. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    I wouldn't be surprised if Russell gave it to him when he moved to his own place.
  11. Ridgeline
    22,724
    123,388
    No you don't, that happens with other equipment.
