Is this crack on my 5th wheel sliding plate normal?
Discussion in 'Questions From New Drivers' started by xzmpt, Oct 25, 2025.
  1. xzmpt
    xzmpt Light Load Member
    100
    83
    Nov 22, 2022
    I recently accidentally hit my air slide button in my semi truck. So naturally, I get out to check and make sure the pins are pushed in. I noticed that one of the notches directly to the left of the locking pin has a crack in it. I don’t know if this is normal or not. This is my first time looking at it since this is a newer truck Freightliner Cascadia, 50k miles. The other side doesn’t seem to have one that is symmetrical. I did the tug test and everything is good. Is this normal? And I’m talking about the crack on the inside of one of the holes NOT the one on the outside between the two holes.
    tscottme Thanks this.
  3. tscottme
    tscottme Road Train Member
    I've never seen that before. But honestly, ALMOST every 5th wheel I have ever looked at had enough grease and dirt to cover such a crack. Also that's the part of the 5th wheel I wouldn't look at very hard anyway. I would mostly just look at pin engagement and cracks near the bolts holding the 5th wheel plate to the frame. I don't know what I would do in your situation. I guess I could tell you it's always better to be too safe than not safe enough. That's probably what drivers are supposed to say.
    hope not dumb twucker, 201 and xzmpt Thank this.
  4. SmallPackage
    5,918
    19,002
    Dec 20, 2019
    Marion Texas
    Don’t think those are cracks. I’ve seen many rails pieced together like that so no material is wasted when made.
    86scotty, MACK E-6, xzmpt and 3 others Thank this.
  5. wore out
    wore out Numbered Classic
    17,978
    226,644
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    You’re right I don’t believe those are cracks at all.
  6. TripleSix
    134,514
    Agreed. Second pic, the outside rail underneath the actual 5th wheel plate has the exact same cut inverted.
  7. 201
    201 Road Train Member
    12,964
    26,718
    Apr 16, 2014
    high plains colorado
    I think it's not a problem, connections to the frame are important, however, it's good you noticed that, good job! :thumbup: I could make a joke about "crack in my 5th wheel", but the gals may not like it, :eek:
  8. '88K100
    '88K100 Road Train Member
    1,503
    3,694
    Aug 23, 2020
    Looks factory to me
    Google a pic of new fifth wheel of same model #
  9. 77fib77
    77fib77 Road Train Member
    12,093
    80,776
    Jul 7, 2010
    St Louis
    I would ask an expert?????
