Is this fuel rail pressure normal?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by crucar1800, Dec 21, 2024.
  1. crucar1800
    crucar1800 Light Load Member
    188
    72
    Sep 21, 2012
    Is this fuel rail pressure normal? at 700 rpms. DD15. 2017. Thanks! Untitled.png
  3. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    That is almost 7000 psi. Most common rail engines will been around that low end and around 28,000 - 33,000 psi high end. Depends on the engine. Any engine I have seen will have "Fuel rail pressure desired" or something like that show what the ECM is expecting or commanding. Watching desired compared to actual is the best way to know if the pressure you are seeing is normal or not.
    QUALITYTRUCK, Stay Puft, Oxbow and 3 others Thank this.
  4. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    You need to disclose year and motor for anyone to say.
    The paccar mx13 runs at 7k to 30k.
    If google is correct.
    I don't know about Detroit, cummins or cat.
    Heavyd and Big Road Skateboard Thank this.
  5. 062
    062 Road Train Member
    6,347
    34,012
    Oct 20, 2013
  6. crucar1800
    188
    72
    Sep 21, 2012
    Thanks. It is a DD15. There is no code nor check engine light. The pressure reads 441 with no issues. I wouldn't know if there is low pressure issues. Any information is appreciated.
  7. 062
    6,347
    34,012
    Oct 20, 2013
    Top of the screen under the actions tab is a fuel system test,I don’t remember what its called, but it will let you monitor commanded vs actual.
    bjytech and Oxbow Thank this.
  8. snowwy
    20,612
    13,333
    Jul 6, 2009
    What software is that?
  9. Goodysnap
    Goodysnap Road Train Member
    3,779
    9,212
    Jul 12, 2017
    As @Heavyd stated…..
    441 bar is = to about 6396psi
    And normal for Idle PSI on any common rail fuel system.
    QUALITYTRUCK and Heavyd Thank this.
  10. crucar1800
    188
    72
    Sep 21, 2012
    Detroit Diagnostic Link
  11. crucar1800
    188
    72
    Sep 21, 2012
    Thanks Goodysnap. I wasn't aware of the bar unit equaling to psi.
    Goodysnap Thanks this.
